SmartBar SmartBar
Post Info TOPIC: Thetford Toilet Flushing Constantly
Can anyone help me? I have just replaced a fitting which connects the wiring from the pump and the reed switch to the control panel, and now the toilets flushes constantly. The only way I can stop it is to remove the fuse.
Has anyone come across this before, and have any idea what might be causing it?
Dave
Davo
Silly question maybe but did the wiring you re-connected go back the right way?  Sounds like it thinks the flush button is being pushed.
Could it be stuck?  Assuming it flushes by a button.
Neil & Lynne
Pinjarra
Western Australia
I kept the old part that I had cut off to make sure I put the wiring back the same way so I am pretty sure it is the same as it was previously. Regardless of this perhaps I could try changing them around?
Yes it does flush with a button which still seems to be functioning ok.
Davo
