SmartBar
Post Info TOPIC: 4x4 Water bladders for additional water?
Anyone out there used one of these 4x4 Water bladders for extra water.  We were thinking instead of taking a hard plastic 60L water tank for roof rack that perhaps one of these water bladders would be better and when not required we can collapse it, but if need water when out driving for the day then we always have it with us.  Has anyone used one and if so any one in particular better than the other?  links below in case you are not sure what I am talking about.
http://www.ebay.com.au/itm/85L-Water-Bladder-4x4-Australian-Water-Bladder-Tank-1500mm-x-450mm-DW85BL-/221332807415
http://www.ebay.com.au/itm/Drinking-water-bladder-110-Ltrs-for-4x4-Camping-Fishing-or-Boating-DW110B-/321146572299
Julie
Do not go where the path may lead,
Go instead where there is no path,
and leave a trail.
Been used for years in boating.  One consideration is ensuring it is well secured.  An 85l bag is a potential 85Kg projectile in a crash.  I personally don't like the idea of just putting it between the seats as shown unless also secured down.
Pete
I'm just a CAD at heart
Thanks Pete
Julie
and leave a trail.
The Marine, Water and diesel bladders I've bought have always had moulded "tangs" in same material to tie down with.
We found that for drinking the best NON tasting ones were the"Plastimo"
I had 150 and 300ltr water and 1 ton sausage diesel for long away trips to supplement my 2 x 30 gall stainless fuel
and the 2 x 40 gall water. (Yacht).
The water ones were still good at over 20 yrs in bilges when I sold boat.
The diesel wasn't Plastimo (Blue\white) but a Yellow one?. Lasted around 7 yrs then sprung leak in bilges.
By-By.
Make sure you "soften" any hard angles\corners.
Plus I fastened down a H,Duty netting over and on top of tang mounts. to relieve stress on mounting points.
But on Yacht they really do move around offshore.
By-By.
 I have a 100L Bladder similar to those mentioned but it is just a 'sausage' shaped not designed for a footwell.  I carry mine in the tup when filled.
I find it invaluable when staying in one spot for a week or three, we always go to or through town a couple times a week & fill it to bring back to the van.
I have a pump set up to speed up transferring the water.
I would prefer a Footwell type so as to move the weight forward somewhat balancing the car better.
Neil & Lynne
Pinjarra
Western Australia
There is also this one, you can put it in the foot-well and stack other things on it.
KFT
We too have a 100L bladder that sits in the rear footwell
It was made by an Aussie company called fleximake based in Dandenong Vic
the one we have is very similar to the one in this link www.fleximake.com.au/Home/EachProduct
very happy with it and been using it for around 7 years now.
It makes transporting water and refilling so much easier.
Frank
Avagreatday.
Yrs ago.
They used to recycle old Plastics. and reuse in a sheet form. Dark green in yarying thicknesses 1\4 in 1\2 in etc.
A lot was sold to make dingy's etc with.
and hot soldered together.
I made one to play with. got a lot of rough treatment with yachts etc in boat club and spent around 10 yrs on mates'
dam as toy for kids fishing, redfin and trout.
Wish I could remember name of it or mfg.
I'd make a coupla water tanks for ute.
Dark green flecked look it had and quite rigid.
Would be perfect for us. cut to suit. hot weld blade together and bobs everybody's uncle.
Fleximake 110l anything smaller only has one connection, I got the moulded one for 100 series cruiser wouldn't be without it one of the best things we ever bought as it folds up so small when not in use.
Darrell
darjak
