Post Info TOPIC: Serial number 3 way fridge
Have a 90 litre 3 way fridge and want to know where the serial number is located. Would like to check if it is a tropical or temperate zone model. Thank you
-- Edited by CC Bear on Friday 17th of February 2017 08:44:08 AM
Our Rig
TUG 2017 Ford Ranger Wildtrak
If it is a dometic open the door and at the bottom rear you should see the details, look for 'climate class' rating, T is tropical.
If it is a 98 model I wouldn't think it was tropical rated.
Just tell us the model number of the fridge and someone here will tell you. However I suggest that you check that the fridge has been installed properly - Dometic Fridge Installation
our dometic 3way has a large sticker on the inside edge of the door - silver with black writing on it
Cheers Bruce
