SmartBar SmartBar
Post Info TOPIC: Winegard antenna, worm replacement?
IMG_2480.JPGHello everyone, I'm replacing the worm, everything is going well....However, when I place the new worm in it sits higher than the older. I can't put the plug back on top as it sits more proud. Has anyone encountered this before? Many thanks Stenno
-- Edited by Stenno on Sunday 15th of January 2017 01:46:07 PM
Hi Stenno,You need to check to see if you have the correct size worm gear shaft.There is a 14inch and a 12 1/4 inch shaft. If you have the correct one then there is a possibility that the worm gear is not mated in the correct position on the elevator quadrant and may need to be wound on. It is a while since I have had one apart but I suggest it is just an alignment problem. Hope this helps.
Thanks very much Patrol03 - really appreciate you taking the time to respond. I will have a look tomorrow and have a tinker. Cheers mate.
Thanks Patrol, I jammed the plug down and it worked well. All done and dusted. Problem solved.
