Post Info TOPIC: heron q split system air con
Does anyone know if Heron q condensor unit, ie the bottom floor bit has an actual drain hose? cant see one but getting a drip of water from moulding area between floor and wall when on cooling mode.( Got rid of wasp from condensate line, which flooded inside seat, now need to invent a screen). cheers and thanks Craig
Cheers Craig
Hey.
For screen on that and outlet gas line on fridge.
I use a roll of Stainless mesh from dishwashing item.
Just cut off to suit with pr of sidecutters. and push in there.
Apart from that.
A spray of Contact poison around them from fly killers does trick.
Thanks Macka
Cheers Craig
Air Command tell me today that condensate " just dribbles out" of bottom of grill if installed correctly.Will pull it(grill) out and investigate as Paramount contact away till end of month.
Cheers Craig
