Post Info TOPIC: Companion emini evaporative cooling
we were wondering if anyone has used one of those companion mini evaporative cooling systems? What are they like in terms of cooling? Are they noisy?  only have a small van and just need something for the nights, any other rechargeable suggestions?
I looked at them last year when they were $99 now $128 from vic supplier on ebay.
But if I was buying one would probably look at the Transcool model sold in Oz for $299 , but do not know about the additional water tank cost but would set it up to have ice blocks etc in the external tank.
To me they are still a bit noisy, but so what if it cools you down, but don't know about the build up in humidity. last web address is a test on the unit.
Note To me the Mighty Kool and the Transcool are very similar to the unit sold in Oz. BUT I may be wrong.
www.youtube.com/watch
-- Edited by PeterInSa on Thursday 29th of December 2016 01:44:22 PM
Thanks will check it out
I have one of the mini models. In the coastal areas of qld they created a lot of humidity but a lot less in the drier western districts. The noise is a bit of a problem as you have to have it close to you to feel cool. my  motor home was a 3.6 metre long living space. I will not buy another if this one fails.
Jeff
Living a life long ambition
Thanks Jeff - very helpful
To me nothing beats a roof top a/c or split system, I only looked at these units since we go to CMCA rallies and generators cannot be used for a/c. Or when parked in city streets for lunch on a hot day this and similar locations could be a potential use for these units. We also have the Sirocco 12v fans..
