Post Info TOPIC: caravan levellers
caravan levellers
does anyone know anything about Kojack levellers or similar?
I had never heard of them, albro so asked my head Brave, nope, not him as well so asked my good friend Mr Google. They look good and so easy to use but wonder how they would go long term if staying put in one spot for a month or more??
Looks fancy. Doubt if I would want or use it.
I Prefer my levelling chocks . I thought I would have to 'muck around' a lot to get level,
but got used to it very quickly . BUT . I Still prefer to jack the side up that needs levelling ,
than to drive or back up . Oh , and about 7/8 times cheaper.
Gunna Go
We Have a Kojack with our new van.
Place under the jack point, level the van, lock down corner jacks. 5 minutes max. Easier than drive on levellers.
Kevin Kyle
On the road full time with Son and 21 year old cat and 3 year old Manx.
Toyota Landcruiser 100 series V8.  Nextgen semi off-roader.  3 120 AH agm batteries, 1KW Solar
Hi Kevin K (Snippy),
I looked at the Kojack some time ago but thought that the cost didn't really justify buying one. Instead I bought a pair of ramp levellers. But maybe now that I am getting a bit older anything to make things easier may be worth a second look.
Just a point - the Kojack frame goes under the wheel and not under a jacking point. Or is there another type of Kojack leveller around? (Google 'Kojack leveller' for a short video of the jack in use.)
There was another type of 'powered' leveller available but the name escapes me at the moment although I recollect that it had an European sounding name. I checked with Caravans Plus as they carried other caravaning items from that manufacturer but they didn't have that particular leveller. Anyhow, I thought that the other one would be better than the Kojack as it had plates on the bottom of the frame so that it could be used on soft ground, whereas the Kojack only had a pipe frame. As I remember the second leveller had a higher lift than the Kojack. It also cost more than the Kojack.
Sorry I am unable give more information about the second leveller but a little research should locate it.
Murray
Additional info:
Goggle 'Milenco Aluminium Leveller for Caravans and Motor Homes' and check out the video. Looks good but expensive. A feature is that it comes with a ratchet drive so you don't require a cordless drill. But as I said, it costs more than the Kojack, although if you do not already have a drill you can save the cost of buying one.
Murray
-- Edited by Long Weekend on Saturday 17th of December 2016 09:44:20 AM
 I wish people would give links to what they are referring to. The OP did not specify what he was looking at. Then Dougwe came up with his usual useless comment "Google it." Then Snippy replied with what looked to be this one. Then LWE commented on this one. Will the real Kojak (without the 'c') please stand up. Maybe the OP (original poster) please be more specific.
-- Edited by PeterD on Saturday 17th of December 2016 11:34:35 AM
Just had a squizz of their hydraulic levelling system which consists of a 4000kg hyd jack and extension pieces to fit to it. looks okay but not sure value wise ???...
 Yep, your usual nasty reply. Expect nothing different. Looks like the 2% club is getting bigger.
Dougwe,
While you were sleepingconfuseconfuseconfuse
QUOTE:   Yep, your usual nasty reply. Expect nothing different. Looks like the 2% club is getting bigger.
Closer to 4.5% IMO.biggrinbiggrinbiggrin
Sorry everyone - I should have given the references.
For the Kojack (with a 'C') frame this is the one I thought that Snippy was referring to. It lifts the wheel only.
www.caravansplus.com.au/catalog/product_info.php
The other Kojack that goes under the jacking point is essentially only a jack and not actually a levelling tool. Looks like it does all the things that a Trailer Mate does.
https://www.caravansplus.com.au/catalog/product_info.php?products_id=14823
 And for the Milenco aluminium leveller video:
https://www.youtube.com/watch?v=fMkeaxQOogI
Caravans Plus sells some Milenco products but not the leveller; about a year ago I asked them if they could carry them in stock but at that time they seemed to be happy with just the Kojack.
Having put the references in I'll leave it to everyone else to decide what is best for them. If the Milenco ever becomes available locally at a reasonable price then I think I would go for that one.
Murray
PS: I haven't been able to find the Milenco levellers from Australian outlets but for anybody going to New Zealand try this company"
http://www.rvsupplies.co.nz/products/view/milenco-aluminium-leveller-
-- Edited by Long Weekend on Saturday 17th of December 2016 03:26:00 PM
Couldn't really be any more specific than "Kojack Leveller" Peter as that is exactly what they are called!
Hi Murray,
Our Kojack came with the van.  It is like a very large bottle jack with a fitting that connects to the vans jack point.
As in my previous post, jack the van until level, lower the van jacks....done.
Have a great Xmas
Kevin Kyle
Snippy wrote:
Hi Murray,
Have a great Xmas
If you mean the corner legs when you say lower the van jacks, these are only meant to be used as stabilisers, not to take the full weight of the van to level it.
Bill B
Hi BillB,
Yes the jack supports the main weight and the van jacks act as stabilizers, so the weight is shared, although the Kojack supports the main weight.
This setup is in the Kojack manual and recommended by the van manufacturer.
Take a look at this post, some more food for thought.
Levelling a dual axle caravan
Permalink Reply Quote
-- Edited by Snippy on Monday 19th of December 2016 07:31:16 PM
Kevin Kyle
youtu.be/9YxU23yar3o
I am not sure I like the fact that it only lifts from the outside edge of the tyre. If it lifted evenly across the tyre it would be better, IMHO.
Cheers Chris
 https://chrisanddiannesultimaadventure.wordpress.com/
I wouldn't have to manage my anger if people managed their stupidity
 Looks to me it would be putting a large sideways pressure on the wheel too.
I think I will stick (with a C) to my yellow ramps.
Neil & Lynne
Pinjarra
Western Australia
Gooday,
 I bought one of these, all Aluminium, (not Plastic), brought it back from US, saves a a lot of mucking about, can also use it to raise one wheel off the ground completely on a Tandem Axle to change a wheel if needed
Blaylock EZ Jack and Wheel Chock for Tandem-Axle Trailers - Aluminum - 20,000 lbs
Bliss On Wheels
Merry Christmas to all and I hope you all receive lots of presents and happiness. Cheers
Our Rig
TUG 2017 Ford Ranger Wildtrak
blissonwheels wrote:
Gooday,
Coincidence, I was just looking at the Andersen version of this yesterday in Perth.  It is plastic and a similar price.
Neil & Lynne
Pinjarra
Western Australia
Gooday,
Wouldn't mind one but do they work on roller rocker tandems? The Anderson ones don't according to Andersons own their website.
Cheers John
 They will work as a levelling device but you may not be able to get enough lift to lift one tyre off the deck for wheel changing.
Thanks PeterD
Cheers, John.
