Post Info TOPIC: Pro Series Standard Hitch
As any one used  Pro Series Standard Hitch - 275 kg (600lb) ith 30 inch bars?
I rang a Hayman Reece dealer today and had a chatand he recommended the HR 600lb classic WDH @ $733. After a bit of searching I found a local caravan manufacturerwho sells the above for around $360.
Would like to know if any member uses this brand and what they are like. Cheers
This link is from another company just to show you what they are
http://caravansplus.com.au/catalog/product_info.php?products_id=14049
Our Rig
TUG 2017 Ford Ranger Wildtrak
Hr, EAZ-Lift and Pro series, they all seem to be a knock off of one another. I would suggest you look around and get the best value amongst them. I did and ended up with the Pro-series. The ones I would suggest you reject is the old HR Classic series, I went from the Classic series to the Pro series (round bar type) and am much hapier with them.
Thanks Peter have a bit more to work on then revisit this. Would be nice with a small van not to have to use it. Cheers
Our Rig
 When you say small van, how heavy is the ball weight? If it's not too heavy you may be able to use this.
Weight coming in around 150/155 and I have minimum in the van but gas bottles and spare tyre are on the A frame. Rear door van so not much space to store inside around the axle.
Need to pull the front of the tug down a bit. Intend to rerig on the weekend and remeasure then will reassess the situation. Cheers
Our Rig
