Post Info TOPIC: Cleaning pull up blind
We have those pull up blinds that are made of paper like material that is concertined. Has anyone any idea how to clean them? Can't vacuum them don'the want to use wet cloth in case it makes them soft
-- Edited by madcart on Tuesday 22nd of November 2016 11:31:28 AM
Dizzy10
Strange how this pops up . I wipped our folding blinds with spray on carpet cleaner then cloth to clean off .. Then went over again to with weak mix of metho and water to dry .
I`m with Aus-Kiwi.
Not sure about the carpet cleaner, but I use "enjo", possibly the white glove will do the trick; with a mix of metho and water. I use 1 cap of metho to 5 ltrs of water.
Use this on my timber floors (no streaks), windows, bench tops etc.
Try a small area first in a not obvious spot.
May do the trick.
Regards.
Hetho.
thanks guys for your help will give it a go
Cheers Chrissmile
Dizzy10
