Post Info TOPIC: External Antenna
External Antenna
Hi Guys
The external antenna point is on the Right Hand Side of the Van and we sit outside on the Left Hand Side
What are you doing to run lead around van
Hope makes sense
Wombat56
Wombat56 Ron
KFT
G'day wombat56
The point you are referring to is most likely for connecting an antenna feed from a caravan park central antenna system into your TV.
Frank
Avagreatday.
Are you referring to the antenna "feed in" point/connector on the side of the van? I am yet to see a "feed out" connector on the side of a van.
Iza
Iza
Yes Good Question
Not sure
Wombat56 Ron
Feed IN is normally Right side.
I normally took cable out of door to table when watching teev outside.
we have antena out point on the left hand side of our van along with a power point and a tv mounting for waching tv outside, these are mounted in a small outsde locker. Is your van an imported model.
 The older vans without the built in antennas on top were equipped with an external input on the RHS side wall. This was connected the same sort of connector near a power point mounted in a place that was suitable to stand a small TV set. Ite input connector on the ouside was the same type of connector as you have inside you house for your external antenna.
In the rare occasions that I want to watch TV outside the van I just run an extension TV lead out via the corner of a suitable fly screen.  Just lift the corner of the screen out of its track.
If I need to run a TV input from the CPs TV feed I do the same thing thru a window near the TV.
Have thought of putting in a couple of those Eye ball thru the wayy fittings but never get round to it.
