Post Info TOPIC: Clean mud stains off front of van
I'm sure someone has a solution for cleaning mud stains off the front of my van - off the Aluminium checker plate. I've tried numerous suggestions on a small section like WD-40,gumption, kero , metho with no luck. I've read to stay away from acid type cleaners so has anyone a tried and proven solution. Appreciate your help thanks Ron
Hello Ronzo.
I use Autosol Aluminium Polish for all my aluminium bits, including my mags.
For the checker plate I use my 9 inch buffer with a soft wool mop head on slow. Leave to dry for a couple of hours, then buff on moderate speed with a clean wool buff.
Once done you won't need a mirror to see you reflection.
Acts like a polish as well; next trip, the bugs will simply wash off.
Hope this helps.
Regards.
Hetho.
Try a product called PURPLE. Shines up the Ally tanks on the trucks ok.
As Patrol03
Purple is the way to go no hard rubbing at all
Cheers John
Another vote for Purple, but bear in mind for badly soiled areas, it's a 2 stage job, you need the purple green stuff (can't remember the actual name, but you apply first) then the purple polish itself.
brian
