Post Info TOPIC: projecta 25amp charger
Hi all. Was hoping somebody could shed some light on a problem im having with the above charger.
 When i first switch it on the display reads r05.
 I never noticed if this came up before the darn thing no longer charges..
 The display adter a few seconds reads 0.0v, the only info i can gather is that it cant sense the battery.
 Has anybody else had similar experience?
 I kook forward to the constructive replies!!
Kezngaz.
Hi Kezngaz.is your battery dead flat? Have you firstly set the type of battery e.g. lead acid,AGM etc ?
 Hi Patrol.
 Yes batteries are fine.
 Ive found the problem and fixed it.
 When ive cut the leads down in length to tidy the battery area i never realised that there are sensor wires running inside the battery cables and they never got stripped enough to make good contact.
 Ive recrimpped them and alls good.
 The display was showing either dead flat batteries or as it turned out, not sensing the battery.
 Thanks for.your reply.
Kezngaz.
Hi.
I've had a coupla Projecta items over the yrs.
None worked. reliably for long.
Not the best Quality wise.
macka17 wrote:
Hi.
 Operator error this time fortunately!!
 Kezngaz.
