Post Info TOPIC: Venetian blinds in caravan
We have a Roadstar caravan which has Venetian blinds, want take them out to clean, has any one taken Venetian blinds out of their caravan if so hoe do you remove them.
Thanks
Jackie.
there are some little sliding clips on the top of the box section on each end- you may need a knife to get it started then pull it toward you and the whole blind will fall down
Jenny and Barry
Have checked and no clips at each end, we have wooden covers  over the blinds.
thanks
jackie
thanks
jackie
the clips are actually on the top of the blind at each end - but maybe they are not like the more common venetians in vans
Jenny and Barry
Had venetians once.(In Roadstar)
with windows open to sleep They rattled.
Didn't have them long.
plus don't keep out all the light, and cooler/warmer with curtains,
I find.
our last van had venetians n i loved them. When travelling we pulled them up n put an elastic band at each end and to clean them i wiped them over with wet ones and disposed of wet ones. They can come off, there is a clip either end at the top. Good luck.
