Post Info TOPIC: Loose Tow bar goose neck - is there a reason?
I initially put this on the end of a subject of Anti-rattle bolt but wonder if it is better going in as a new discussion.
Could I ask a question? I have a 2004 Nissan Patrol fitted with a Nissan towbar (was on the vehicle when I bought it). From what I found from the previous owner, the car had towed a van of unknown size around Australia before he bought it. I assume it was on the original towbar assembly.
Last year I made Mk 3 version of my stone guard. This time it was fixed to the car, not the van & bolted to the body underneath & also fixed via a square Ubolt to the gooseneck (for added support). When we arrived home, the LHS bracket had snapped, the RHS had started. As I was rewelding a new bracket, it hit me - I have the bar connected rigidly on the ends but moving up & down with the goose neck. There is approx. 3-4mm of movement. For a lot of the trip, we had our camper on the back (est ball weight of 120Kg) & we went over some "interesting" roads - well I assumed they were roads!
Can anyone tell me why the goose neck is made to be quite loose? Ease of insertion? There is no anti-rattle bolt on the bar to adjust. There must be a valid reason other than to frustrate amateur engineers!
It is loose because the outside dimensions of standard section square tube is smaller than the inside dimension of the receiver standard size square section tube.
Special size tubes would reduce the rattle, but would cost a heap more.
And it does not matter.
The anti rattle bolt (if fitted) should not be tightened up when towing, just when not towing. It is a bit of a waste of space anyhow....
Toyota 200 series LC's with a genuine tow bar have shims that need to be fitted to eliminate movement in the hitch.
When the shims are fitted the hitch is quite firm in the bar itself.
Over on the LCool Toyota forum there are reports of drivers actually being defected for excessive movement between the hitch and the bar while towing.
Possible overzealous policing but apparently it has happened.
Travel safely..
-- Edited by Dickodownunder on Wednesday 22nd of June 2016 11:41:44 PM
Travel Safely
In the old days we had a tongue fixed semi-permanently to the towbar. Generally with two large bolts requiring a similarly large spanner if we ever wanted to have it removable. Some towbars even had the tongue welded as part of the bar itself. Fashion, safety, convenience have all played a part in the trend to square receivers and easy removable hitch. And we, the motoring public, and they, the manufacturers andregulators have accepted the loose fit as being good enough. Some of us, and I daresay the minority, take steps to take out the excessive play but for most it's just the way it is. Somewhere down the track, an enterprising soul will present to us a cheap alternative that has no play whether loaded or not.
Remember, it's not necessity that's the mother of invention, it's dissatisfaction that's the mother of invention. If you're not satisfied, you may be the inventor we've been waiting for.
Must be a non-original tow-bar, all Nissan tow-bars have an anti rattle bolt to my knowledge?
Cheers Keith
Our land abounds in Nature's gifts, of beauty rich & rare. We'll be out there enjoying it somewhere, camped by ourselves much of the time.
Yes my Nissan has a genuine tow bar and is fitted with a small rattle bolt. When it is not tightened the tongue has just the slightest bit of play in it which doesn't concern me.
Col
(Picture of my beloved Molly (2003 - 2016) who loved the travels as much as I do. RIP old girl. Gone but never forgotten).
Can be easy fixed by drilling and putting another bolt through 70 or so mm past the original Pin. Having a single pin allows movement . Btw a good high tention bolt with nylock nut fits much tighter also .
Hello Keith,
It is a genuine Nissan bar with "NISSAN" stamped/attached all over it. I thought perhaps it was mounted on the top of the bar (& under the aluminium step) but there is no sign of the bolt or any hole it went into.
The bar on my previous GQ (1992 model) was almost the same but that didn't have a genuine goose neck. Perhaps the anti-rattle bolt/screw is a later model addition.
The anti rattle screw is used only when a tongue without a load is in the tow bar receiver. If you are towing there is no need to use the anti rattle screw..if you do you will strip the thread..no anti rattle screw then.
The bottom of the square sectiion on the towbar that takes the male section of the tow hitch has a small set screw in it the screw would strip if you tensioned it to take the movement out of the hitch the downward pressure would be immense .
Haveing said that a set screw mounted on the top would probably work ?
I don't think so Ron.What about the stress when you adjust the WDH to distribute the ball weight to the front of the towing vehicle. If you need to stop all movement when the van is hitched then an appropriate size shim would need to be fitted.
Good point Patrol03 your right....
By the way Warren,When I had a 92 GQ there was no anti rattle screw provision in the receiver.If it annoys you when the van is not attached,try a couple of pieces of ice-cream container strips in with the bar or drive a thin wooden wedge in the space to quieten it down.
Thanks patrol03,
Your name - does that mean you've had three Nissan Patrols? I too am on my third & probably last. The first was a 24v MQ (had it 16 years), next was a 92 GQ 4.2D (12 years), the current one is a 2004 GU TD42Ti. It had 271,000 Kms on it when I bought it - now has 366,000 on it in 3.5 years. Someone in Kununurra said I'd get 1,000,000 out of it (so I'm working on it).
Back to the subject - noise is not the issue - it is my stone guard holding bar that is attached to the body (underneath - there are two 8mm screws that are convenient) & to the gooseneck for support. One of the previous brackets snapped possibly on the Winjana Gorge Rd in the Kimberleys, the second started to crack but I have made newer & slightly heavier ones.
