Post Info TOPIC: Flick mixer tap
Flick mixer tap
I have a Smev cooktop and stove combo in my van. The flick mixer tap has started leaking and in my opinion needs replacing. The question is can I replace it with one purchased from Bunnings provided its the same diameter hole or do I have to go via a caravan parts supplier.
Bryan
"Smev cooktop and stove combo" "Flick mixer tap leaking".  Mate, I'm confused, yes I know, easy for me. I assume it is the water tap leaking confuse I am pretty sure they would be the same at the big green shed. Maybe take the problem causing tap in with you.
Make sure you turn the water off first mate biggrinbiggrin
You are not allowed to buy anything else while there though wink
Just get under there and go for it.The taps come with new flexible leads so you should not have any problems.
 Heh Heh, it should have been cooktop & SINK.biggrin
I had a look at the big green shed Doug but I think from Caravan plus. Don't ask me why - I think its a comfort thing.
Thanks Patrol03, I'll give it a go. I hope access is easy and I don't have to bend this not so supple body too much.
Bryan
Had to take the sink out of our Expanda to get to the nut that holds flick mixer, It's easy to get to the water pipes
Full on to full off is very quick. This can induce water hammer to three times the normal supply pressure. Eg. 360 to more than 1000 kilo pascals. Like a car decelerating when it hits a brick wall. Many times seen washer rubber and ceramic leak because of this.
 I hope I'll be able to get to it from underneath. Being a cooktop combo, I am scared I may do damage to the gas connection.
Bryan
 Never thought of that Tony. I'll bear it in mind for both caravan and home.
Bryan
Have you fixed it yet Bryan ?????
Do a Youtube search on this and it will show you how to pull the tap apart while in place and service the trap
 Thanks Brickies I'll have a look. If I can get it right I'll hold the new tap as a spare.
Bryan
 Not yet Doug. I'll do it in early July once I've got the van home. Its parked at the factory (about 100kms from home) and I use it a couple of days every week instead of travelling up and down, until I finally get to retire at the end of the month....I hope
Bryan
Thanks Bryan. Sounds a good idea having the van to stay in for a couple of days. Bring on the end of the month. Only a couple of weeks left mate.
-- Edited by Dougwe on Saturday 18th of June 2016 09:01:47 AM
Most flick mixers have replaceable cartridges that can be changed like you would change a weaping washer in a traditional tap.
Dis-assemble yours - take the plastic hot-cold indicator plug out, loosen the allen bolt under it and take the whole tap handle off.  Take a picture, then lift the cartridge out.
Go to a plumbing store and get a matching replacement.  Put it in aligned to match the picture.  Re-assemble the mixer.
bye.
Bruce & Judy pulling a 3T 23.5' Traveller Prodigy behind a Diesel Range Rover
I know its an old thread but, I had to remove the flick mixer tap out of a 2013 pop-top Jayco last week - need the assistance from a midget contortionist with three arms and an extra hand on the end of the old fella - I think the van was built around the tap
 We had a leak (sorry Doug) from our mixer tap and I pulled it apart in situ and fitted new seals.
They must get them fro IKEA because if I remember correctly I had to use an Allen Key tool.
Don't sell the Sun to buy the Candle
