Post Info TOPIC: LED awning strip lighting
hi all, looking for tips on fitting LED awning lighting, where to buy, roughly how much, that sort of thing
I just bought 5m strip off eBay for $12 - $15 . I used a little clear silastic every 300mm or so to be sure it stayed attached just above strip above wheel arches . Wiring is easy as it's very low amperage . Speaker wire is enough . Can be single if you earth at LED connection . Been working for 3 years fine .. May fit a 2m strip higher ? Lights up just nice .
Leave it as long as you can to purchase LED strip lighting. It has slowly come down in price & will continue to do so in the future. Do you really need your camp to be lit up like a Christmas tree or is it just a novelty? The outside light on our caravan is sufficient for our needs.
Cheers Keith
Our land abounds in Nature's gifts, of beauty rich & rare. We'll be out there enjoying it somewhere, camped by ourselves much of the time.
we just bought a standard 12v 3m strip from Masters while they are discounting. Being a lazy bugger, I also bought a huge pack of cheap zip locks and use them to attach the LED strip to the awning support arms (I use the ones that came with the annexe so I have two supports between the end posts of the awning).
Then when I take the awning down, I just use a pair of scissors to cut off the zip locks and turf them and then roll up the LED light and store it in the front 'van boot.
I got a blue LED, as there have been many posts on here in the past that blue lights do not attract mozzies and other biters
Cheers Bruce
Heaps on EBay as cheap as chips any colour you want
Make sure you get clear white (that is the brightest). Also the ones I have bought on eBay always have the 3m adhesive backing.
Last one I attached it to the awning roll and fed the wire thru the edge of the awning back to the van and then under a rubber strip on the top edge of the van to under the van.
Glen
Cheers folks for all your replies. Will keep looking
I bought some "yellow" led strip lights, thinking that they would repell insects...........nope did not work.
                          A day without sunshine is like, well, night.
I recently purchased one of these strip lights and am very impressed. https://www.4wdsupacentre.com.au/products/4wd-lights/led-strip-lights/illuminator-max-led-strip-light.html Fully dimmable, velco or hooks for attaching to awning rafter.
Ian Hardwick
I have a 5m length that is portable and can plug into cig lighter socket nd be rolled up onto a reel, similar to an old 8mm movie strip.
Also have bought 5m length and cut into pieces ie over stove on back of truck, power usage doesn't show on amp meter versus 1A for older light.
Also fitted LED globes in 2 van side lights with increased lumens (light) and 0.5A current draw versus 2A for older globes.
Seems to be a win/win to me and cost is very minimal.
Hi all;
        I too have a 5mt led strip and also bought through E-bay. $15.00. 12 Volt,low current draw and came with 3M backing. Great light and now no dark areas under the awning. Well worth the time and effort.
