Post Info TOPIC: Water pump
Water pump
good morning everyone, when we switched on the water pump t did not work. Anyone else had this problem? Regards rocket n strop
Yep fuse on the Ctrek charger
hi graeme c , where can i find the ctrek charger? Thanks
First find if power is getting to the pump with one of those voltage testers that look like a screwdriver fro SuperCheap for about $10...if no power then work backwards along the cable to switch then fuse then battery.
Good Luck.
Is it just the pump ? Or has low voltage relay kicked in ?
Hi Rocket,
Is the pump running but no water, or is all quiet down there?
Actual pumps can calk it too.
I have one (dead) in shed.
