Post Info TOPIC: Best place to get 9kg gas bottle filled or swap
about to head to port Augusta and just wondering best place get gas bottle filled/or swapped
If you have a 4c Coles Shopper Docket and need fuel, I would try the Coles/Shell Garage just south/entrance to Port A. Swap over for $25. Purchase up to 150 Lt of Fuel for 10c/Lt discount (spend over $20 in store ie the Gas)+ the 4c Shopa Docket off the listed price. Total 14c/Lt discount off the fuel.
Only need a small quantity of fuel, maybe cheaper elsewhere.
Thank you will go check it out, thanks Peter.
JCT
I am a member of the group shown below.
it aims to show members the cheapest places in all areas to refill or exchange gas bottles.
I suggest you think about applying to join, there are are no fees/charges, why not take a look?
https://www.facebook.com/groups/BBQGasBottleRefills/
Thank you , have just joined your group , thank you again .
is there a Bunnings near you, about $21 swap last time I did one
Mechanised Swaggies
Bunnings Port Augusta also do refilling of cylinders.
Hello , we have googled Bunnings locations and it seems there isn't one there , we did ask at the mitre 10 the other week but they wanted $39 for a 9 kg bottle and we didn't buy there,
BCF used to refill 9kg bottles for $19.95. Recently upped the price by $3. Still the cheapest if you want refills, rather than swapping
Cheers Bruce
And last but not least we always use BarbQues Galore to fill our bottles where possible. $20
Dave
Sorry for previous - it is Mitre 10 - they do refills www.bing.com/local%7e137.784362792969&ppois=-32.48291015625_137.784362792969_Mitre10&FORM=SNAPST
I got two 9kg bottles filled for $23 . It was across the road from .. Cheap as Chips .. From Memory Flinders Terrace .
Where ever is the closest , Can cost more to run around looking for the cheapest if you need it you need it just like tug fuel
Yep I asked one of the locals ., Nothing like local knowledge . Up to $60 at service stations !!
BCF and Rays are both the same company and do a 9kg refill for $16. Unfortunately, if you call in on a Saturday morning they may be too busy to do it right away and so mid week is better.
