Post Info TOPIC: Isuzu Dmax & Ultima Cafe 5th wheeler
$80 000
Isuzu Dmax 2014
35000 kms
Clearview towing mirrors
Dual battery setup
electric brakes
Bull bar
Uhf
After market extras
2 X 120w solar panels
2 x 100ah agm batteries
2nd tv in bedroom
Eberspatcher diesel heater
Includes Hayman Reece evolution hitch $4000
CAFÉ STANDARD FEATURES
METALLIC SILVER GEL COAT EXTERIOR
ALUMINUM FRAMED, DARK TINTED SAFETY GLASS WINDOWS
DIAMOND PLATED STEEL REAR BUMPER
DOOR SIDE (REAR) PATIO AND SECURITY LIGHTS
EXTRA CURB SIDE TV CABLE HOOK-UP
EXTERIOR 240 VOLT POWER POINT
E-Z LUBE HUBS
15 INCH ALUMINUM WHEELS
EXTERIOR SPEAKERS
REAR STABILIZER JACKS (2)
ELECTRIC FRONT JACKS (2)
RADIUS CORNER ENTRY DOORS, BAGGAGE DOORS AND WINDOWS
PRIVACY GLASS ENTRY DOOR
ACCENT COLORED ALUMINIUM SKIRTING
ACCENT COLORED FENDER SKIRTING
RAIN GUTTERS AND EXTENDED DOWN SPOUTS
BREAK AWAY SWITCH
LCD TV BRACKET / HOOK UP
MATCHING BAGGAGE DOORS
REESE REAR PIVOT EXTENDED PIN BOX
DEXTER 2700KG (6000LB) RUBBER RIDE AXLE, ELECTRIC BRAKE HUBS (WITH FULL AUST/NZ WARRANTY)
INTERIOR
ACCORDION STYLE DIVIDERS (WHERE APPLICABLE)
SOLID WOOD MORTISED CABINET DOORS
SCREWED AND GLUED CABINETRY
ENHANCED COOL RUNNING 12 VOLT LED INTERIOR POT LIGHTING PACKAGE
DÉCOR MIRROR
RAISED PANEL WOOD OVERHEAD CABINET DOORS
WALL MOUNTED INTERIOR LIGHT SWITCHES
PADDED NO CRACK VINYL FLOORING THROUGHOUT
KITCHEN
STAINLESS STEEL POWER EXHAUST RANGE HOOD WITH LIGHT
KNIFE RACK
PLYWOOD DRAWERS WITH BALL BEARING GUIDES
CORIAN (MARBLE TYPE) COUNTER TOPS
DOMETIC SS (AGA APPROVED) 3 cu ft, 120 litre 12V/LPG/240V REFRIGERATOR/FREEZER
SMEV STAINLESS STEEL 3 BURNER COOK TOP WITH GLASS COVER (AUST MODEL AGA APPROVED)
STAINLESS STEEL 240 VOLT MICROWAVE/CONVECTION OVEN & SURROUND
STAINLESS STEEL SMEV MATCHING SINK WITH GLASS COVER
BATHROOM
SKYLIGHT OVER SEPARATE SHOWER
LARGE MEDICINE CABINET/MIRROR
RECESSED OVER HEAD VANITY LIGHT
TOOTHBRUSH HOLDER
WATER SAVER HAND SPRAYER IN SHOWER
POWER EXHAUST FAN
TOWEL RAIL
TOILET IN SEPARATE ROOM
BEDROOM
QUEEN BED AND MATTRESS - 6' 6" L X 5' W (Please note our recent brochure's "features" section went to a new format and incorrectly included pillow top mattress. We regret an inconvenience.)
BULLET READING LIGHTS ABOVE BED
NIGHT STANDS
DOUBLE 240V OUTLET AT EACH NIGHT STAND
HANGING WARDROBE WITH TWO DRAWERS
OVERHEAD STORAGE
COORDINATING DESIGNER COMFORTER
LIFT UP BED WITH GAS STRUTS AND STORAGE
TV JACK AND LCD TV BRACKET
LARGE STORAGE AREAS UNDER FOLD UP STEP TO BEDROOM
UTILITIES
SATELLITE / CABLE HOOK-UPS
WIRING TO ROOF FOR SATELLITE/SOLAR PANEL HOOK UP
WATER PUMP/FILTER IN OWN COMPARTMENT ACCESSIBLE FROM EXTERIOR
OUTSIDE SHOWER
CO, LP, SMOKE DETECTORS
FIRE EXTINGUISHERS (2)
PROBELESS TANK MONITORS
ONE-TOUCH SYSTEMS MONITOR PANEL
240 VOLT- 12 VOLT CONVERTER
ADDITIONAL CAFE CONSTRUCTION
VACUUM BONDED WALLS, ROOF AND FLOOR
ALUMINUM FRAMED WALLS, ROOF, AND FLOOR
HIGH DENSITY, POLY STYRENE FOAM INSULATION IN WALLS, FLOORS, & ROOF
SIX INCH HYBRID BOX SECTION/ I-BEAM CHASSIS WITH FULL OUTRIGGERS
PROBELESS ROTO-CAST HOLDING TANKS
CAFE VALUE PACKAGE (INCLUDED)
FULLY ENCLOSED UNDERBELLY
FIVE SIDE ALUMINUM STRUCTURE
AM/FM/CD/DVD (CODED FOR AUST/NZ ZONE 4) W/INTERIOR/EXTERIOR SPEAKERS
2 x 4.5 KG GAS BOTTLES WITH AUST MODEL AUTO GAS REGULATOR (GAS BOTTLES NOT SUPPLIED FOR NZ)
6 GALLON SUBURBAN (AUST MODEL AGA APPROVED) LPG/240 VOLT WATER HEATER W/DSI
PORCELAIN TOILET W/ FOOT FLUSH PEDAL
HIGH OUTPUT EXHAUST FAN IN BEDROOM
OUTSIDE SHOWER
TWO A&E POWER AWNING (ONE ON KERB SIDE AND ONE ON REAR)
SLIDE TOPPER
SPARE TYRE AND CARRIER MOUNTED UNDER REAR OF CHASSIS
SWING OUT GRAB BAR
PLEATED SHADES
METALLIC BRONZE FIBREGLASS FRONT CAP WITH LED LIGHTS
13,500 BTU DOMETIC DUCTED 240 VOLT A/C WITH HEATING
RADIAL TYRES
TV ANTENNA (STANDARD POP-UP TV MECHANISM FITS UPTO 32" FLAT SCREEN TV)
CAFE SPECIFICATIONS
DRY (KERB) WEIGHT APPROX 2100 KG (EXCLUDING AWNINGS, SPARE AND AIR COND)
PAYLOAD APPROX 600 KG
PIN WEIGHT APPROX 360 KG (DRY & LEVEL)
2800 KG ATM
INTERNAL LENGTH APPROX 19 FOOT 6 INCHES 5944 mm
EXTERNAL OVERALL LENGTH APPROX 22 FOOT 6705 mm
EXTERNAL WIDTH 7' 4" , 2235 mm (OUTSIDE WALL TO OUTSIDE WALL)
FULL HEIGHT SLIDE-OUT
EXTERNAL HEIGHT EXCLUDING AIR COND 10' 1" (3050 mm)
FRESH WATER CAP 140 L (inc HWS)
GREY WATER CAPACITY 120 L
BLACK WATER CAPACITY 120 L
ALLOY WHEELS 15 INCH
2 x POWER AWNINGS (KERB SIDE AND REAR)
2 x 4 KG GAS BOTTLES
-- Edited by Glenelg on Thursday 5th of May 2016 01:34:51 PM
Dave S
iv'e lost my glass.
I reckon that toothbrush holder in the bathroom will be the selling point of a great package mate.
Good luck with the sale Dave. Great price too.
Hi, Have you sold. If not would you consider separating.  Chasing a Isuzu Dmax.  And where are you located.  Frankie sunny North Qld
