Post Info TOPIC: Replace Air con
Replace Air con
Hi all ,we need to replace our air con but what is the best Nowdays ?
looking at the Dometic BR 342 I believe these are relatively new? Has anybody one of these installed or can you recommend a replacement modelno
Dhutime
I'd forget a caravan rooftop model and look at a domestic reverse cycle air con. We went through this exercise 16 mths ago and after sacrificing 2 overhead cupboards and the generator box on the rear bumper we couldn't be happier with our new air con - total cost $1600 - a quiet and very efficient option
Jenny and Barry
 Exactly what we are doing.  We have a new Jayco on order & have specified that there is NO air/con.  I will be fitting a domestic split system, probably a panasonic after delivery.
Hey Villas, what size a/c did you fit?  I am considering either a 2.5kw or 3.5kw. same physical size & weight & only $100 difference in price.  I don't want to be underpowered but overpower is not good either.
Cheers Neil
Neil & Lynne
Pinjarra
Western Australia
go air command sparrow .....an Ibis 4 years no trouble
Thanks for your input I have looked at the domestic units but cannot fit one of those unfortunately .
Still hoping someone has a Dometic 342 installed who can give me first hand info .
Seems like they were released 2015 has 3 kW cooling and 2.9 heating
