Post Info TOPIC: Thanks. What rims fit a 1998 Jayco Westport
Hi - just joined the forum since we bought our Westport three weeks ago and have been on a shakedown trip ever since.
Its been a bit torrid at times but all in all pretty good.
Anyways I want to get some rims and tyres for the van that are an inch or so bigger so we can get a bit more ground clearance.
Its got the roller rocker suspension and seems to have a decent bit of room in the wheel arches.
What vehicle rims fit the stud pattern? I know our GQ will take Pajero rims as an example.
thanks in advance for any tips.
Cheers from Rick
Hello rrakausk
Welcome to the forum, I do not have a Jayco Westport, but I am sure that others with this model will be along to answer your question
If you were to take your spare wheel into any reputable tyre place, they could measure the PCD and by looking up their charts, they could tell you what vehicle manufacture uses those rims.
They could also tell you if you could fit higher profile tyres on your original rims.
Enjoy your stay as this is a very good informative site
thanks for the tip Tony.
Simple solutions work hey?
Cheers Rick
Yep . Seen some with mighty high profile . Look good too . New wheels on tug . Old tug wheels on van ..
Our Westport has light truck tyres on steel rims. See pic.
1996 Jayco Westport 16'
Pic shows steel rims so just went out and checked the tyres on the Westport. They are:- "HIFLY 185R14C SUPER2000"
Prices approx $85-$100 each (fitted and balanced), available from Jax and others. https://www.jaxtyres.com.au/tyres/brands/hifly/super2000?pid=85259
Fitted new June 2015. Done approx 10,000km on them and estimate approx one third wear. Provides 212mm clearance from ground to axel.
102 load rating (850kg). 16" van has a Tare of 1080kg
