Post Info TOPIC: Thetford Toilet elect water pump switch not working
Has anyone pulled apart the Toilet water press part on the top of a 2011 Coromal Element 542 toilet?  I thought it was a Thetford toilet, but not too sure now as I downloaded a Thetford Toilet Repair guide and can't locate anything that looks like it!
Assistance appreciated.
Glen
Glen
Glen,
May not be the pump switch but the pump. The pump impeller in one type of Thetford is under the toilet roll holder and held in my a SS Screw, undo the screw and out comes the pump with a frozen impeller, use a screw driver to turn the impeller to unfreeze ( may take sometime) and the pump will work again. Have heard some use a dash of dish washing fluid to keep the pump/impeller lubricated.
However if the impeller is frozen once without use every so often it will happen again.
All sorted out. It was the controller - the circuit board had popped out of the holding pins and once back in, it works fine.
Thanks
Glen
Glen
