Post Info TOPIC: Motor Home Storage a Web Netting
Hey Guys :)
For Cloths & Bedding storage, me finks a good idea is to store them on the inside rear walls of my 1999 Mazda E2000 LWB?
For this specs, However I am require to get manufactured Custom Elastic Netting to Tech onto The internal rear walls above bed height?
Does anyone know at all, where one may get such manufactured?
I Have contacted 3 Net Making company's, however no such luck as of yet :(
My Specs & Pic of Internal Rear Wall, it had to be upside dowm too :(
Specs Email Sent :)
Dear Sir / Madam,
I am inquiring as to wether or not you can make 2 small flexible nets for me?
1. They must be of flexible elastic nature, and long lasting!  as they will be fitted to the walls of my Camper Van to store items of clothing, pillows & doonas etc.
2. The nets must have the ability to be Tech  screwed down in place on the sides & the bottom, preferable the edges that are being Tech Screwed down, ( I'm presuming that Tech screwing them to the walls is the best way? ) I'm suggesting the edges should be min of 20mm wide? Also maybe  you already have such edging with metal grommet holes for the purpose of screwing down?
3. The top edge could be either elastic cord or elastic strip, flexible enough to pull from the wall prefferable around a min of 200mm ? & also something that is going to be long lasting?
4. The overall dimensions of each of these 2 Nets should be 1350mm  X 500mm including the edges.
5. If your company is able to manufacture such nets for me, ideally could you please send me some pics of the materials you will use or at the very least a written description?  upon your Quote reply.?
6.  Upon you quote, please include the cost of shipping etc.
7. Failing I have not included any other critical info, Please do Email or Ph me back with your Questions :)
7.  Failing you are unable to manufacture such small nets, if possible could you please let me know as to whom I can get them manufactured from.
Cheers :)
Ron
-- Edited by messiahmonkey on Wednesday 17th of February 2016 11:47:05 AM
Fav Quotes:
Where there is a Will, there is a Way! :)
I know my Shit! I just don't know where I Put it! :(
Here ya'r El Presidento - up the right way
John,
How the Freak did ya do that???? Do you have a Smart Computor or what :)
Cheers :)
Ron
President of the Planet :)
Fav Quotes:
The Happy Helper
Ron - you will find some of the people on here very helpful - even fix your pics for you!!!
jules
(Ben, aged 10)
try marine chandlers- used in yatchs for soft storage
blaze
