Post Info TOPIC: Rubber window seals for Viscount caravan
Hi all. I have a 1985 Viscount Aerolite caravan. I have some water leaks from the windows, so want to change the rubber seals around the glass. Having trouble locating that particular seal. Have been to Clark Rubber, while they have a good range of rubber seals they do not have the one I need. Has anyone had this problem and found the correct seals anywhere.?
better off trying the local domestic window makers they usually have a number of rubber sizes for their different types and thicknesses of glass.
Peter and Robyn heritage
Camec would probably be the best place to start, if You are not near one of their stores try their web site or phone them.
Mike.
I obtained new rubber window seals for my 1981 Viscount from Dario's caravans in Adelaide a while back so perhaps check them out on line. Another caravan parts place is Cararest also in Adelaide and I found they also carry a lot of spares etc. Good luck
