SmartBar
Post Info TOPIC: Leaking roof - Winnebago Esperance
We have an intermittent leaking roof.  Leaks appear around the air conditioning unit and the sky light areas though not all the time no.  Can anyone suggest a solution or experienced similar problems or suggest a reputable EPDM roof repairer in Sydney?.  Thanks
FraLyn
We have a Winnebago Explorer I believe has similar hatch. The problem with mine was the original installation. From inside when you take off the trims and remove internal fittings (not hard, just screws) you will find the screws holding the top section down. The correct method of securing is using 3/32 threaded bolts. Winnebago in their wisdom use tek screws that are too short (would have busted up the plastic if longer), which is fortunate because only 3 of the 16 actually attached at all to top section (albiet by only 1 thread) therefore not damaging the internal threads. Because of the thickness of the roof I was not able to obtain off the shelf bolts to do the job. I purchased a length of rod, cut to length and used a dome nuts to fix in place. It all works and water proof now. I have no idea how the hatch stayed in place, obviously only the stickyness of the foam sealing tape that actually held hatch in place  for 5 years.
Good luck
Neil
There's the guys out Avida Head Office
32 David Road
Emu Plains NSW 2750
Australia
PO Box 420
Emu Plains NSW 2750
Australia
Phone: 02 4735 8116
Fax: 02 4735 8070
www.avidarv.com.au
Read more at www.avidarv.com.au/contact-us
Who could do it for you .. ?
I
32 David Road
Emu Plains NSW 2750
Australia
PO Box 420
Emu Plains NSW 2750
Australia
Phone: 02 4735 8116
Fax: 02 4735 8070
www.avidarv.com.au
I
 my concern would be if they would repair any better than the original build. By the way, Winnebago aren't the only company that don't instal things according to instructions.
Neil
Shoot the messenger.. If it was there fopar they can fix it.. It's an option ...
I've had my Avida back to them 5 times to fix a leak and other poor workmanship under warranty - they take weeks and it comes back still leaking
Is it condensation from unit ? There is a rubber paint which can apply to keep EPDM in top condition..
Check YouTube ... But the rubber must be sealed first .. Water leaks can be pita to find and cure ..
Thank you all for your replies. I will be doing some more research prior to proceeding with the next step.
FraLyn
Avida Birdsville 2020 bought new in July. Rain comes in through air-conditioning onto our bed Third time back to dealer and still leaking. Haven't been able to use it since first rain in WA Anyone else? any suggestions?
marlene fuller
KFT
 Hi you have tacked on to the end of a very old thread.
You may get a better response if you start a new topic
Frank
Avagreatday.
FraLyn
 If it's a Winnebago Esperance it is at least 5/6 years old..
I would suggest you take it to a good repair centre and have all your roof sealants checked.
Monty. RV Dealer.
Get Similar colour Sikoflex and go around joints . It self levels, seals . Put it over screws etc . Dont worry it doesnt look ugly ! Cant be seen . Then paint area for better UV protection .,
Original post is dated 14/11/2015
Bill B
Frank (FraLyn) has not been around since 10:39 Mar 19, 2018, no good addressing him.
