Post Info TOPIC: hot water taps
hot water taps
Am looking to install a hot water tap in my van.
Got info on the Alpha HWS tap which heats from a coil in the tap unit. Sells for about $250- $320.
Other options as gas and electric systems pose other issues in my van but willing to hear back from any experiences that you may have had.
Hagar45
R L Hagan
Hagar45
 Hi Rod
          Had a simler Hot tap in my previous van ,it did the job but very slow on delivery and it was all plastic.
Lance C
The cheapest and quickest way to get hot water is to put a pot on the gas stove, or if you are on 240V power, then use an electric jug.
"Instant" electric heaters usually disappoint.
Have seen the tap heater units at number of van shows and don't believe they were that expensive suggest you shop around if going that way
Just a thought if you install an on demand gas water heater and plumb it into the van you can have an external shower and sink hot water at mains pressure for around $200.00 if you shop around , I think I posted an article on a suitable system, if you search the achieves there will a few in there I'm sure
If you travel and stop over night ? Maybe for 2 nights ? A heat exchanger off the heater coolant hoses heats water hot enough to do dishes etc.. A coil inside a stainless or alloy tank .. We made one up on our charter boat we had..
Thank you.
Am going to OFF Road show to follow up.
regards
R L Hagan
This was a "wifey" request which may lapse for want of a seconder.
Your option is certainly  cheaper and less stressful.
regards
Hagar45
R L Hagan
Looking at next show.
regards
Hagar45
R L Hagan
Not a good idea, they are limited in their efficiency.
We went through three RV Hot Water units fitted at the sink, all failed, either blew the circuit breaker or burned out, needed 15 amp power point as well, we bought a Birko instead, does the job, from a power point.
There are no shortcuts to hot water at the sink.
Bevan
Friendship is not a relationship with someone whom you've known for a long time,
but with someone you trust, under any circumstances.
Thanks,
With all the responses to date even my wife is backing off!!!!!!!!
regards
Hagar45
R L Hagan
