Post Info TOPIC: Fusion RVCD800
Fusion RVCD800
We have a Fusion RVCD800 unit fitted in our van. in the source menu it gives you the option of Bluetooth, radio, Aux and TV.
we want to know - is the option for TV for setting up the TV to hear through the speakers in the van.
we think, we can recall, the salesperson (when we purchased the van) telling us we could listen to the TV thought the Fusion Unit.
we are trying to watch a movie (through a USB )) but the sound is so low we cannot hear it. The TV volume is 'up' as far as it will go.
if we could link the Fusion with the television we could probably be able to hear the movie better.
help if you can,
thankyou
Looking at the manual for your unit, your source selections are:
SELECTING THE MUSIC SOURCE
Press the source button to cycle through the following
sources
(if available) Radio> CD> FRT USB> REAR USB>
SD> BT AUDIO> AUX1> AUX2
You would need to connect the audio output from your TV to either the front or rear AUX inputs of your stereo unit. Either via a 3mm stereo audio connector from the headphone jack of the TV if it has one, or via the audio RCA outputs of the TV, to a 3mm stereo audio connector that plugs into the AUX socket on the front of the stereo, or RCA connectors to the rear AUX input of the stereo unit.
