Post Info TOPIC: tricks or tips for travel ?
taking off in the next couple of days for a try out  of the old van
so a few  things to ask  as its been a long time since i used a van  and , no im not off rounding  but   a few of the miles  will be  un made  dirt
do clothes stay on the hangers when you travel   ?or do the hangers bounce off the rails  ( vague memory that everything ended up in a heap on the bottom of the wardrobe )
what sort of things do people do  to protect crockery etc  ? do most use plastic ?  i know there lots of fancy gadgets to hold plates  etc or should i just pack in boxes
 overhead cupboards only have  spring hinge and a magnet  to hold them shut  is that enough ? or will i need to add  extra catches  quite firm but  just  not sure if they will hold if stuff pushes against them
are you  better off to pack liquids into  containers so no spills ? ie  bottles detergents ,sauces  etc
have a strap around the microwave   which is on top of the frig  on shelf about inch clearance at the top  and  rails to hold the feet  , but should i put it on the floor  for  weight distribution  / risk of  damage ?
how about dust  is there anything that i can do  to stop it   ? the door has a large vent in the bottom of it   and no way to shut  it off , if on really dusty roads would i need to plastic and tape it ? does much dust get in around the pop top  asking this as have been to a camp spot the last few years and end up spending good couple of hours  just sweeping the dust out of the box trailer after  ( its really fine  dust )
do fluro bulbs survive  in a caravan not to delicate  to survive the bouncing  about  of the van ?
thanks david
david heath
David Hi,
Clothes, I have a piece of stretch cord that puts a little pressure onto the top of the hangers, trousers I put a peg on, rarely have a problem.
Crockery I have a plastic coated dish drainer screwed to the shelf & stand the plates etc. as if they were drying, cannot bring myself to use plastic. Cups/glasses are inverted on non slip matting. You could put a piece of light cardboard between the plates if You wanted.
Cupboard doors should be okay, I have screwed my microwave in. Fluros should be okay if worried put them under the blankets on Your bed (remove before getting in there).
I have found that packing everything as tight as possible reduces breakages & marks etc. I have small trays to put things into in the fridge.
Dust ! gave up trying years ago.
LOWER Your tyre pressure. I work on 20 percent  rule, get onto dirt reduce by 20 really rough another 20. reduce your speed accordingly. Your tyres are pneumatic and designed to absorb shock so having them as tight as a drum to try & save sixpence worth of fuel doesn't make sense to me.
Mike.
We bend the curved top part of our coat hangers into a slightly more curved shape, they don't fall off the rail then.
In cupboards we use plastic containers from places like Storage World, keeps most things in place.
Cups & glasses are kept in the boxes they came in.
-- Edited by Desert Dweller on Tuesday 15th of September 2015 06:46:13 PM
Cheers Desert Dweller.
Our land abounds in Natures gifts. Of beauty rich and rare.
Wardrobe? Hanging clothes?
We put shelves in our wardrobe and can now accomodate more items We don't take fancy clothes on trips (come to think of it, we don't own any!).
Crockery is melamine. Cups are on cup hooks and often fall off on rough going, but don't break. More importantly the wine glasses are suspended upside down as in a bar.
Cupboard doors. Mmm Are they hinged on side, bottom or top? That would make a differnce. While you are finding out whether you have a problem, I would suggest populating with lightweight inexpensive items.
Microwave: if you can't secure it to your satisfaction, I suggest you leave it at home as repositioning it at every stop will soon become tiresome.
Dust: If you solve this problem there will be a lot of us indebted to you.
Fluoros: We changed ours to LED strips, but didn't have any problems before that.
General: It is good that you have thought about potential problems in advance, but don't let these concerns affect your plans. Running modifications are possible. Get out there and enjoy.
BJC
"A year from now you'll wish you had started today."
