Post Info TOPIC: 2004 Matilda Bradstreet on Isuzu NPR350
G'day everyone, We are the proud new owners of one of these gorgeous motorhomes. Does anyone know the genuine height from rooftop to ground please? I do suspect we won't be using an underground car park Thanks in advance for your help.
Ray & Janet Be alert, Australia needs lerts
Looks good well done. I have no idea of how high it is. What I done was go out with me tape, differant makes differant sizes I need 3.4 clearance on my 5th wheeler. Lots of low roofs on servos more so the older one
Dave S
iv'e lost my glass.
Without sounding facetious, wouldn't a tape measure be easier and more accurate to find the size of your rig ?
I measured mine on day one, nearly 4 years ago, simple 3.2m clearance, no guesses or false info from some other similar rig that may or may not be different anyway.
brian
Thank you Glenelg and banjo, I did use a tape measure so discovered anything over 3.8m will be fine. Mind you, I leaped out of the truck and double-checked at the servo. I believe this is one of the last Bradstreets to be made, the dealer was hazy and I have lots of questions about how things work. My husband will have to do a lot of hunting and testing, lol.
Hi the best way is to use a step ladder and tape you need to add the air con on top so on a step ladder run the tape from top to grond and eye in the top of the air con and add 100mm for safety you will get a more precise measurement this way good travels
