Post Info TOPIC: Tandem axle Trailer Aid or a Jack with no moving parts
I came across one of these yesterday - Trailer Aid
$40 - $90 depending on where you shop
It's supposed to work on independent suspension although I'd want to try before I buy on a sooper dooper off road rig
-- Edited by Kendo on Saturday 8th of August 2015 10:04:07 AM
-- Edited by Kendo on Saturday 8th of August 2015 10:08:36 AM
Live Long and Prosper
MN Triton auto diesel 4x4 & 20' 6" Kokoda Tribute II XL Platinum
Wouldn't leveling ramps achieve the same thing?
Dave
See you on the road
confuse Maybe?
but these were a little higher than leveling ramps I've seen and they give a "flat spot" or an area where everything comes to rest.
I particularly liked the idea of there simplicity and ease of use. Apart from having to have the strength (or leverage) to undo your lug nuts they almost seem too easy to use.
I can imagine numerous situations where a Trailer Aid would be so much safer and easier to use that a conventional jack (soft or sloping ground, not physically able to use conventional jack, etc).
I sure if you've got the time, inclination and tools. It wouldn't be hard to make on of these as well
I bought an exhaust operated lifting bag. Works well on soft and uneven ground. Lifts 4000 kgs and no effort on my part
David
ps. cost $120 from memory.
-- Edited by nimrod on Wednesday 12th of August 2015 01:46:20 AM
David
2014 Colorado Dual cab with canopy and boat loader
23 foot Western Homestead
If you always do what you've always done, you'll always get what you've always got
This ramp idea is a great idea BUT its another bloody thing to store away and carry.Might have to leave the cook home if I keep buying all these gismos.
Gooday,
 Am expecting to get a similar piece of gear next week or so only it is aluminium from US. Will let you know how it goes in time, the video I have seen looks very impressive.
Is solid Aluminium.
Mouseover to zoom.
EZ-JACK
EZ-JACK
EZ-JACK
EZ-JACK
EZ-JACK
EZ-JACK
Blaylock EZ Jack and Wheel Chock for Tandem-Axle Trailers - Aluminum - 20,000 lbs
Bliss On Wheels
On my tri axle van on the chassis next to the mud flap is a support bracket that the wind up jack attaches to. I just clip on the jack and wind up until level. To check if the van is level I use a 4foot spirit level. I level it length ways using the jockey wheel and the wind up jack for levelling cross ways.
Mutt.
These look pretty impressive
www.levellingjacks.com.au/index.php/2012-07-04-02-04-22/rv-accessories/camper-leveler-wheel-chock-25-detail
