Post Info TOPIC: TV, aerial and radio not working
hi was hoping that someone could help us please or has anyone had a similar problem with a Jayco Starcraft 2014 model. Our TV, aerial and radio no longer work although they have been fine for the past 3 months .  I have checked the actual TV and this works when plugged into another 12v socket. There seems to be no power to the socket but it's strange that the radio also doesn't work. All the fuses are good. Anyone with any ideas?
Don't know the van but look for a lose wire Behind the wall plug it's possible if they are close together that they draw power from the same lead and most of the time it will be the earth rather than the live wire at fault .
Happy hunting
Thanks we wil try this
Presume that the fuses are blade type like ours has. Double check them as often a blown one looks OK but of course it isn't!
Murray
Thanks they are the blade ones and are ok we even put in new ones just I. Case. could only find the fuse for the radio though mentions nothing about TV.
The TV has a mast head amplifier that works off the 12 volts. As I said in techies corner swap the fuse with another to see what happens. As far as I know they all use the same circuit. Our Starcraft (2013) does.
