Post Info TOPIC: Solar panel on top of ute
I did try to install my 200 watt solar panel on the top of my ute's roof
Magic happened it did work, I can angle it on both sides
Thanks for the members that gave me some advise
Cheers John
-- Edited by Cruising Cruze on Thursday 16th of July 2015 08:26:19 PM
-- Edited by Cruising Cruze on Thursday 16th of July 2015 08:29:40 PM
Well done John.
Cheers. Col & Annette.
Adventure before Dementia.
Exactly the set-up I had mind. I found a site on the net, where you enter your location, month of the year and the angle of the solar panels. At this time of the year June July,according to this program, the difference in power generated by a panel going from 0' (flat) to 43' (angled) was 100%. Of course as the sun moves higher in the sky, mid summer the effect is not as great.
Hi Iana can yopu tell us what the name of that site pleasesmile
Dizzy10
Sure thing solarelectricityhandbook.com/solar-angle-calculator.html.
Called:- Solar Angle Calculator / Solar Panel Angle Calculator.
thanks for that Info Ian
Cheers John
@ Ian
Was after all not to hard to do the job on top of the ute's roof
I still have to put the Sikaflex on
That's a job for tomorrow if we have the right wheather
Cheers John
-- Edited by Cruising Cruze on Sunday 19th of July 2015 09:05:56 PM
We have a solar panel on the roof of our ute.
Charges a deep cycle battery in a box on the back. ( The back of the ute is closed in with purpose built checker-plate alloy boxes.)
Can plug in another panel on legs to move with the sun.
