Post Info TOPIC: Removing Red oxide stain from vans galvinised frame Help
Hi all,
Need some help in removing the red oxide staining on the leeding edges of galvinised frame. I did a search but came up empty. Googled same and came up with.
1.Ranex by Bondall. From Bunnings. But will it damage the gal ????????????????? Help please.
2. Alu- Clean by Cyndan. again as above.????
3. CT18 truck wash.??????
Your help please if you have had the same experiences and use / results.
Regards  Jim
Try wd40 , removes paint ,glue and even lubricates,or maybe prepsol.
-- Edited by exa41 on Monday 13th of July 2015 04:21:22 PM
Dennis and Yvonne .
Retired sparky of 50 years.
JUST COASTIN`
Hi Dennis & Yvonne,
STOP THE BUS EVERYONE, I brought a 250mm bottle of  Ranex by Bondall at Bunnings this afternoon for $12.29.  On top shelf under rust remover stuff. Read it five times Good for stains Not Good on painted Surfaces, colour bond, or Gal.
So slow and steady boy, we will do a test patch underneath out of site so to speak. Just a dab on a household spong. If this doesn't work I blow $12.29 ( I'm wearing disposable gloves) OMG it just started to wipe of before my eye's. Bucket of water to wash down residue.
OMG  its like brand new again like I had just picked it up from the dealer. I'm on a WINNER here. It says not leave wet, towel it dry. WOW WOW WOW. lets keep going. I just don't belive it. I have done one hour so far changing the water with each section.
By days end tomorrow, I will have back, my camper. JUST added $$$$$$$$$$$$$$$$$$$to resale.
The Ranex = Phosphoric Acid Trade strength. So far I have used 25mm of the stuff.
Im so excited I'm taking Lambie out for a feed.
Hey Jim & Lambie
Make sure you really wash it off well or after a day or two the gal becomes a dull grey colour.
Sounds like a red dust problem ????
if it is, try some aluminium cleaner It will do the job
Spray it on in the right dosage and Hit it right away with the gerny
good luck
Cheers John
Hi Troupy,
Don't worry applied heaps, and tomorrow will take the camper out of the shed and wash it down continuasly with the hose as I go so not to get it on the paint work.
It so great I sill can't believe it.
jim
Hi John,
Its red oxide from up around Mt Tom Price. Its all but gone by tomorrow. Thank the Lord.
Jim
Well I hope you still have some gal left by tomorrow.
from their website:
* Note: avoid contact with vehicle paintwork, Colorbond ®, dry concrete, anti-fouling paint, marble & anodised or galvanised surfaces.
Hi troopy,
You made me go look.
Sorry to say, I did use plenty of water section by section and dry by hand, all good.smilesmilesmile
thankyou anyway.
Regards Jim
 Mate; that is potent stuff. Used to use it back in the 70/80's when doing rust repairs on cars. When all the removing & replaceing of rusted sections we would sand off with a sanding disc ; then mix this acid with water about 10 to 1 & brush it on repaired area to do the final clean, let it dry then wipe off with a damp cloth to leave a coating, very good result before any filling was done.
Dont try spraying it; the fumes will kill you.
How strange this should come up, only a few days back I ran into a guy that ran a chemical store at home where we used to buy it from & had to think hard as to what the name of it was. LOL
JC.
JC.
If you're all excited about using phosphoric acid, you could have used Coca Cola.
It contains phosphoric acid. Good stuff.
The Phantom
Hi JC,
Your not wrong about  its strength, I'm about to continue on it now, out in the open so I can use the hose at will.
You can under stand why its only found on the top shelf in the store.
Rubber dub dub, I'm off to scrub. ha ha.smile
Hi Phantom,
Your not wrong, I can tell by your eyes.biggrinbiggrinbiggrinbiggrin
Jim
Hi everyone,
Thanks all for your imput.
Its all done and looks a treat. Very Very happy chappie.smilesmilesmilesmilesmilesmilesmile
Regards Jim
Sounds good Jim.
PS: use a old tooth brush to scrub it into the metal. It lifts as you watch.You MUST keep the water up to it. Slow as you go. Small section at a time.
Jim
Yes,I remember phosphoric acid for rust treatment.It used to come in a black fluted plastic 500ml bottle with a red top.I think there is still one on my shelf in the shed.Good stuff when prepping rusty steel prior to painting.Wash it off,let it dry,fill,undercoat and paint.Great stuff.Just be careful it doesn't effect surrounding paintwork.
There are many different rust removal and rust treatment products available that contain phosphoric acid, with differing strengths. Even, as someone else mentioned, some softdrinks contain small amounts of phosphoric acid.
-- Edited by 03_Troopy on Thursday 16th of July 2015 11:16:40 AM
