Post Info TOPIC: Nitrogen top of Van tyres
Permalink Closed
Hi all,
Our new Jayco van will come supplied with Nitrogen filled Tyres.
Were does one check and fill up with Nitrogen air?
Jim
Permalink Closed
I think Bob Jane has nitrogen so I,m guessing that other tyre shops do it too.
2015 Ranger XLT - 2014 Jurgens Sungazer
Permalink Closed
You can top up Nitrogen tyres with air if you have to with no problem
Permalink Closed
Nitrogen in tyres - WOFTAM. See this link
Permalink Closed
It's not V8 Supercars where 2lb tyre pressure can make a difference in grip..
Nor is tyres as in plane getting cold enough to freeze any moisture in three..
Permalink Closed
I suggest a prize con trick for the bulk of folk.
For aircraft, we use nitrogen for two reasons - dry (so not a freezing problem at -50C odd) and nil oxygen (for tyre fire considerations)
Permalink Closed
Air = 78% Nitrogen, 21% Oxygen and 1% various trace gasses.
Putting Nitrogen in caravan tyres = 100% wank biggrin
Cheers, Steve.
"Any day above ground is a good day... unless you're a spelunker  :)"
Permalink Closed
As stated above, there are particular reasons nitrogen is used in aeroplane and racing car tyres. The ONLY advantage to using it in your Van or tow vehicle is that nitrogen takes a lot longer to bleed thru the tyre wall compared to normal air. What amuses me is that tyre is never properly evacuated before they put the nitrogen in.
Regards,
Mike L.
Permalink Closed
James Bond would never be able to survive sucking out a car tyre underwater when it's pure nitrogen.
Permalink Closed
And how much do Jayco charge you for the privilege of putting nitrogen in your tyres
The Phantom
Permalink Closed
 I tend to agree, air is free Nitro is around $6 a wheel.
Permalink Closed
Hi Phil,
I that case, just maybe I can ask for a free top up under Jayco Warranty.smilesmilesmilesmilesmilesmilesmilesmilesmilesmilesmile
NB: Better ask to blowem up to 45psi on delivery....biggrinbiggrinbiggrinbiggrinbiggrin
-- Edited by Hey Jim on Tuesday 9th of June 2015 08:34:56 PM
Permalink Closed
This must be Jayco`s  answer to stop their vans from falling apart.biggrinbiggrinbiggrinbiggrinbiggrinbiggrinbiggrin
Permalink Closed
 Hi Mike196,
If the normal air bleeds out faster than nitrogen,  what is it that bleeds out, the 21% oxygen?? If so you end up with the 78% nitrogen anyway !! plus the 1% assorted stuff.  This is just the usual crap idea to justify the cost !!
As said already a complete wank and a commercial opportunity to sell crap ideas to the gullible punters IMHO using some suspect facts.
Permalink Closed
I have used nitrogen in all my vehicles tyres for the past 15 years or so mainly because I had free access to it but found that I never had to top up my tyres and I got nearly double the mileage as they never heated up on the road. Nitrogen is an inert gas and won't freeze or heat up. That is the main reason they use it in aviation. I hope this helps. Regards Phil.
Firey Phil
Permalink Closed
Hi Phil,
Sorry to say this but the facts do not support your statements. "twice the mileage " YOU WISH hmm
If you have good brand tires with a quality lining then the pressure loss is minimal WHATEVER THE GAS IS INSIDE. I recall doing a test at a tire shop many years ago on a reps car with Mitchelin tires and it went for a complete set of tires without putting air in them. hmm No nitrogen BS back in the late 60s.
Permalink Closed
130,000 on a set of desert duellers with still plenty of tread when I sold the troopy. Go figure!
Firey Phil
Permalink Closed
130,000 with plenty left? Yeah, right.
Permalink Closed
 So, using that theory, Liquid Nitrogen is the same temperature as gaseous nitrogen? Actually it's the flexing of the tyre that causes heat, which in turn causes the inflation gas to heat up and expand. Maybe nitrogen doesn't expand as much as ordinary air, but I couldn't really be bothered to look it up as someone else pointed out... in an ordinary motor vehicle, or van.. a TWOTAM.
Permalink Closed
What is this a pissing contest?
Firey Phil
Permalink Closed
Haha, good to see you live up to your signature firey Phil smile
It's not a pissing contest mate, but if you put up misleading and completely incorrect information you're bound to cop a bit of a pasting.
Suggesting that using nitrogen in your tyres will double their life isn't just misleading, it's utter nonsense.
An inert gas is one that does not react with other substances, it has nothing to do with how it responds to temperature change. Nitrogen will heat and cool just like any other gas, or any kind of matter. Nitrogen and oxygen expand at almost exactly the same rate with temperature change.
You may have access to free nitrogen, but for those that would have to pay for it, it's worse than a waste of money. Using nitrogen will in fact cost you more in the long run. At $5 per tyre to top up, even topping up twice would far outweigh any increase in tyre life you might think you'll get, which I believe to be zero in any case.
Cheers, Steve.
Permalink Closed
Oh God put this thread to bed!
Permalink Closed
What is this like a gang here? Lets all get together and beat the the **** out of the new bloke. CMG's have tried it. I thought you gn"s (obviously only in this little group) would be above this sort of bulling, but if it's in the gene pool and there is no life guard so be it.
CMG (Criminal Motorcycle Gangs ) for the non informed.
Firey Phil
Permalink Closed
Phil, come and join me. We'll be a gang of 2 (supported by a few who often PM me as they don't wish to draw attention to themselves)
I often get set upon by the resident Einsteins.
I travel to the beat of a different drum (as the song goes) and some of my sarcasm flies over their heads at several hundreds of Kms/hour.
It has passed long before it sinks in and all they can revert to is verbal bullying. But, I'm a resilient type and can give as good as I get and manage to stay under Cindy's radar.
Just remember the old saying about arguing with fools, being dragged down to their level and being beaten by their experience. Heed that and you'll enjoy it here.
The Phantom
Permalink Closed
Thanks everyone for your input; however I think it's best to close this now.  Although we welcome robust debate in this forum, we will not tolerate personal attacks. Please ensure that posts are positive and respectful.
