Post Info TOPIC: Jayco Sprite
Jayco Sprite
My brother is thinking of buying a Jayco Sprite can someone please tell me the pros and cons of these vans and also if you can, the overall height, as it needs to be able to fit in his  rather low garage .
Thank you in advance
Dhutime
I think that the Jayco Sprite is a camper trailer that folds down very low. So it should fit into any garage!
The Sprite is quite small and I personally would go for a larger camper trailer unless he will be travelling alone - maybe a Hawk?
Murray
Sorry everyone - I am wrong - I was thinking of the Snipe!
Murray
-- Edited by Long Weekend on Tuesday 12th of May 2015 04:34:49 PM
We have a '98 Jayco Sprite. It really is a single bed Starcraft and ours is 12' long. No problem fitting under the average carport and garage with pop top down. The way to tell if it is a single bed model or double is the amount of windows at the front. Ours has two because of the wardrobe between the beds. The double bed model had one long window with two tiny cupboards beside the bed.
We love ours as it is light (780kg tare) and just a bit wider than the car so reversing through the gates in our drive is easy. The height with the top down is about 2m.
Hope this helps.
I'm not lost, I'm here.
