Post Info TOPIC: Leaking Grey Water Tank
Hello all - I am having trouble with the drainage hose on my grey water tank. It is leaking where it joins onto the tank so I am thinking I will have to buy a new hose and perhaps a new tap. Could someone please advise me as to what I need to buy and also the best place to buy it from.  Thank you in advance.
Where there is a will there is a way!!
Maybe you could just cut that section off and get new fitting Nelly. Try plumbing section or Irrigation section of the big green shed first. Otherwise a caravan accessary place should have the fittings. Maybe even Reese.
KFT
Hi Nelly, what Doug said is good advice,
can you put up a photo of the tank fitting and the hose fitting so we have some idea of what you have?
then we can give you some advice on what options you may have.
frank
Avagreatday.
