Post Info TOPIC: Water hose
Water hose
Stop the water spluttering and spurting by priming the hose before you connect it to the van
Too easy!.....a great idea and so simple.
Good luck.
Great idea,   tried it and it works.
Thanks
I used to be addicted to soap,  I'm clean now.
Either do that or connect the hose, turn the park tap on and then bleed the vans system by turning on the external tap until the air is out of the system.
I connect the hose, open the relief valve on the hot water system until the water flows, then close it. . (always drain the HWS after each trip)
Regards, Moby
2017  Land Rover Discovery 3.0 & 2013 23ft Coromal Princeton 713
