SmartBar Camp Creative
Post Info TOPIC: Duel batteries in tug
When you set up duel batteries in the tow vehicle through the Redarc isolation switch ,do you run your wires for the fridge freezer in the back ,off the crank battery or the auxiliary battery or doesn't  it matter,and also do you  need to put a fuse or circuit breaker on each pos battery  lead to the isolation switch, many thanks.ps if I need circuit breakers what AMP and what AMP fuse if needed.
Lance C
-- Edited by Olley46 on Monday 6th of April 2015 08:11:24 PM
Aux battery for accessories.
Circuit breakers -  NO for staring battery,,, yes for aux battery.
 Hi Baz421
               I am using the isolator switch as a start assist as well the book with the switch recommends 100AMP  circit breaker would it need to be that big,thanks in advance.
Lance C
-- Edited by Olley46 on Wednesday 8th of April 2015 09:27:39 AM
You need a fuse at BOTH batteries as any short to earth in the connecting cable can draw from both. We use 100 Amp fuses as the same cable also runs the van fridge (3 way ) and a DC_DC charger for van battery when required. Total current can be very high on occasions.
I also assume the reason for the auxiliary battery is to run the fridge in the tug so wire it only to the auxilary.
Alan
-- Edited by Brenda and Alan on Wednesday 8th of April 2015 11:08:02 AM
Alan
Thanks Alan for your advice, have just ordered 2- 100 AMP circuit breakers , when fitted should be honky dory cheers.
Lance C
Ollet46 aren't 100 Amp circuit breakers very expensive compared to ANL fuses.
Alan
Alan
 I got 2 for $52.90 of the Internet ,I thought that was a reasonable price, may be I am wrong.
Lance C
Olley46 are they rated to operate with DC current.
Alan
Alan
 They are for a duel battery setup,they are manual reset and water proof.
Lance C
I fitted a couple of these to mine.
This mob have them for $34.00 free postage. I didn't get mine from here though, got them through work at the time.
100A Circuit Breaker.
