Post Info TOPIC: New safe gas canisters for Luchbox cookers?
Was just in Big W and they had a big row of the 220gm gas canisters for the small cookers which are labelled as being safe to use with cookers etc and comply with the relevant regulations.
I wonder if this means we can come out of the shadows and start cooking with gas again?
Good Luck
The Master
I thought it was the cooker at fault and not the canisters.
The double cookers are ok and use the same canisters as the single.
I've still got mine, will use it when I need to but not in the van.
Happy Wanderer
Don't worry, Be Happy!
The Master
This looks like the box I bought from Big W last year, either 12 or 16 in the box. If so I already have them. A great buy.
Happy Wanderer
Wasn't it the canisters that were exploding?.....going by the label these are safe to use. Monkey see, monkey do.
The main problem was people putting oversize pots etc on the stoves, & this over heated the gas canister. Or not putting the trivet up the right way when using. People not reading the instructions that come with the stove. So I gues its easier to just ban the sale of them.
D.L.Bishop
The Master
They've only banned the single cooker. All canisters are still in the shops, I've just been for a walk around some.
The problem lies as others have said in not using the single cooker properly causing the canisters to explode.
The double cookers are ok as bigger allowing larger pan on without covering the canister area.
Happy Wanderer
I agree with Daryl and Marj - its how you use it, not the product that's always at fault.
Im in Coober Peedy and theres about 6 shops that sell hardware/camping gear including the major servos and IGA. All of them have the single cooker brands that I seen banned in most other States. Don't know if theyre banned in SA as well - but obviously out in the country they apparently thumb their noses at these sort of withdrawal and banning notices
Cheers Bruce
They're banned in SA too. However we will still use ours outside and carefully as we have done for more than 10 years!
Di
BruDi
Main problem, as has been said, is too large a pot, forcing the flame/heat across to the canister which has been exploding.
Those canisters are only a glorified beer can under pressure, with no relief valve. So they explode when over heated.
Choice Online has an article on them also in this months news letter, based on NSW and SA banning them. choice.com.au March news letter.
Australia has safety standards for stuff like this, but too many company's are bringing in non compliant cheap imports from overseas, and of course we buy them because they are cheap, and even so they may be OK but pays to read the directions. If possible buy something that quotes Aust Standards on the stickers.
Our Gasmate is on the hit list too, so we are thinking we'll replace it with a compliant low pressure stove with a regulator that runs off a portable (Primus) gas cylinder.
Needs about a 2 metre hose so the gas bottle sits on the ground and the cooker on the table. (Outside only!)
Bevan
Bevan
Friendship is not a relationship with someone whom you've known for a long time,
but with someone you trust, under any circumstances.
According to the link below for ABC News item, the way I read this issue is that the cookers were banned from sale Australia wide early February ....... correct me if I am wrong. We still have our single and double cooker and will continue to use them with care. I wonder how long before those camping in van parks will see signs up "Lunchbox Cookers are not to be used in this facility"!
http://www.abc.net.au/news/2015-03-10/scramble-to-determine-safety-of-portable-gas-cookers/6296160
If there was an alternative to the cooker other than LPG gas or an open fire, then I would use it. Like many of us, we read safety instructions and use accordingly. Our cooker is not on the list, but that is no longer relevant as the ban covers all makes/models.
-- Edited by chaslib on Friday 3rd of April 2015 01:08:31 PM
The Maccas ....
2013 Avida Esperance Motorhome - based in northern NSW.
the cooker is at fault as it can heat up the canister when not used correctly
those CRV canister's have vents in the top of the can which release the pressure from the canister, to prevent an explosion
the escaping gas will catch on fire , so you have a fire instead of an explosion
there are some  double cookers on the list not to use
-- Edited by Old Col on Friday 3rd of April 2015 12:26:50 PM
-- Edited by Old Col on Friday 3rd of April 2015 12:30:18 PM
While some have been withdrawn from sale
This is the only one, As far asI am aware, that an official RECALL  has been made
Sitro Group AustraliaTwin Portable Butane Cooker
PRA number: 2015/14630
Date published: 1st April 2015
Product information
Product description
Twin burner portable butane cooker
Identifying features
Gasmate PC2075, PC2080, BuyRight MPC2070 with a date of manufacture (DOM) 48/13. The product has been available for sale from the 1 April 2014 to 1 March 2015.
What are the defects?
The overpressure safety device may not shut off gas to the burner if the butane cartridge canister is overheated. In addition, the risk of overheating increases if the product is not used according the manufacturer's specifications.
What are the hazards?
If the defect occurs, there is risk of explosion and fire.
Dates available for sale
1st April 2014 - 1st March 2015
Where the product was sold
  • Nationally
Traders who sold this product
The product has been sold via hardware and camping stores
Supplier
Supplier's web site
http://www.sitro.com.au
What should consumers do?
Consumers should stop using the product immediately. A replacement unit is currently being tested and finalised and will be ready in short order. Consumers can register to receive a replacement unit or they can contact Sitro Group Australia to discuss an alternative remedy. For further information, please call the Sitro Customer Service Line on 1300 174 876 or email: productsafety@sitro.com.au.
Advertisements and supporting documentation
pdf.gifProduct Safety Recall Notice - Twin Portable Butane Cookers - updated.pdf (220.7 KB)
-- Edited by oldtrack123 on Friday 3rd of April 2015 10:14:33 PM
How many times does the nature of the ban need to be explained. The ban had nothing to do with the use of the equipment but the retail sale of the equipment. If you already have one of these units and the associated gas cylinders there is no legal requirement to stop using it you just may find some difficulty in replacing the gas cylinders or buying new units. Consumers are not required to do anything.
Dave
See you on the road
Here is another slant - I wonder if one exploded/ruptured in your annexe and caused your van to catch fire and be totally destroyed, would not the insurance company argue that you were knowingly using equipment which is banned from sale and deny your claim?
Good Luck.
Dave
Hi Dave
Do you have a reading problem
Try reading it first, before putting foot in mouth
If you bother to read it CAREFULLY ,you will see it has nothing to do with the gas cylinder as such, the problem lies with the  over pressure safety shut of valve in the unit itself
I have posted  Copy &paste of the  OFFICIAL Fed GOV  RECALL of the particular brand & models!
IT IS AN OFFICIAL FED GOV  RECALL FOR THAT BRAND & THE INDICATED MODELS
Best get your facts rightno
PeterQ
-- Edited by oldtrack123 on Friday 3rd of April 2015 10:11:23 PM
-- Edited by oldtrack123 on Friday 3rd of April 2015 10:17:37 PM
-- Edited by oldtrack123 on Friday 3rd of April 2015 10:20:39 PM
Gee some of guys are nasty.
Can't you just make your point without attacking others.
My reading of the 'withdrawl notice' and the associated list is that some 2 burner types (including my U bute $100 one) are not to be sold in certain states.  Had a look in Kmart here in Brissy yesterday & they had the old gas canisters but not burners for sale.
I have two single burner ones too that are too old & knocked about to read manufacturer details.
I'll keep using them.
Now you can have a go at me too if that makes you feel superior or whatever.
Hi Cupie
Obviously you have a similar reading problem
I believe the RECALL notice is very clear
I am  at a loss as to why some people cannot simply read, before jumping in & posting
Read MY post
IT IS NOT the with drawn from sale message that got such wide publicity & confusion  due to some people not understanding what they r were readingno
IT IS NOT the advisory sent out by various STATE  Authorities ADVISING there was a safety risk
IT IS THE OFFICIAL MANDATORY RECALL NOTICE SENT OUT BY THE COMMONWEALTH GOV, NOTE the WORD" RECALL"confuse
It Applies to ALL STATES &  NT & CANBERRA
IT covers THAT ONE BRAND at this stage & the specified model numbers
No doubt other brands will, in time, also be issued with" RECALL "notices
At the present  ,as far as I am aware rTHAT ONE brand is the only ONE that has had to issue a FULL RECALL under orders from the Com GOV dept.
Now I hope you can understand the differences
It indicates what the problem is & it is not the gas cannisters[it is the over pressure flame shut of valve not functioning as required
PeterQ .
-- Edited by oldtrack123 on Saturday 4th of April 2015 12:56:37 AM
Hi Cupie
"Obviously you have a similar reading problem
I am  at a loss as to why some people cannot simply read, before jumping in & posting"
Peter  ..  It is this part of your post that is unhelpful ...
As an invalid argument ad-homonym (in logic - 'attack on the man',  only one step away from an 'argument ad - Baculum' - 'appeal to the stick') it adds nothing to your  overall position.
Perhaps it might be useful to look at the NSW Fair Trading Advisory on this site ....
http://www.fairtrading.nsw.gov.au/ftw/Consumers/Product_and_service_safety/Lunchbox_cookers.page?DCSext.ref=HomePageClick:ScamandAlerts
and its associated table of Products suspended from sale as at 10 March 2015.
This is the advice that I was referring to in MY post.
oldtrack123 wrote:
Dave
Hi Dave
PeterQ
PeterQ, I am at a loss to understand the vitriol in your post  other than your assuming that my post was directed at your post of the recall notice. It wasn't, it was directed at the number of previous comments regarding people believing they were no longer permitted to use this type of equipment and this level of confusion goes back to when the advisory notices were first issued by the NSW Dept of Fair Trading back in the beginning of March (a month before the recall notice you posted). There were a number of reports, at the time, of retailers who had over reacted by removing both the burners and the gas cylinders from their shelves thereby making it difficult to source replacement cylinders. These events produced a number of clarifications from government departments and individuals about the nature of the advisory.
Dave
See you on the road
Hi Dave
It appears I did misunderstand your post ,So my deepest  apologies to YOU blankstare
I took it that you did not agree that the previous advisory notice issued by the various states & the withdrawal from sale notices where TOTALLY different to MY post of the official RECALL for ALL units sold ,covered by that RECALL notification
In fact your comment "consumers do not need to do anything " IMHO confirmed that!
[In fact NOW ,owners of the specied brands & models SHOULD return them to place of purchase or if they cannot get a refund there ,contact the suppliers ]
[They certainly should not just be dumped ,unless completely destroyed.]
Actualy I half expected that sort of responce
It is the sort I have often recieved when posting recall notices  on the netconfuse
People in denial of facts??
The link I posted is very specific
It details the Brand & models numbers  that have been investigated thoroughly to date, & a serious safety problem has been confirmed with those particular listed units
It even indicates the REAL problem!
! The  automatic over pressure gas shut of valve ,which should prevent the gas cylinders from overheating & exploding!
I expect More brands & models will be added as they check & test more, so standby for more such postsbiggrin
Although that recall appears to have been made by the co nmvolved, it is actually by" RECALL AUs"& covers ALL of the Commonwealth  of Aus
You can access that site by clicking on the" contact  Us"on the bottom left side of the notice.
It overides ANY state notification
I recieve around  probably 6 such recall notices every week,  covering a wide range of products, Direct from" Recall Aus"
Again my apologies to YOUblankstare
PeterQ
-- Edited by oldtrack123 on Sunday 5th of April 2015 12:33:55 AM
Cupie wrote.
Hi Cupie
I have no need to look at that link
I received it, Automatically, the day it was issued
It out of date as far as the RECALL notice is concerned
The recall notice CONFIRMs the Problem with the specified brands/ model numbers
Those are the ones that have been PROVEN DANGEROUS &  ARE RECALLED AUST WIDE At this point.
It is very likely that follow up RECALLS will be issued for other Brands& models, once they are inspected & checked
I do hope when I post Those  , they are recognised & accpted AS OFFICIAL recalls with good reasons.
THEY DO NOT COMPLY TO AUST STANDARDS
PeterQ
-- Edited by oldtrack123 on Sunday 5th of April 2015 12:26:15 AM
For the people that haven't seen the explosion from these little cans.
-- Edited by Jenko1 on Sunday 5th of April 2015 09:39:14 AM
Hi Jenko
Yes, that does what can happen if the can explodes But the can exploding is just the final chapter
IF the safety gas shut of valve does not function, even THOSE cans will release gas, which may well be ignited by the actual burner flame
Result, a Bloody big flame &NOT just in the burner !!!
The only safegaurd is a fully functional gas shut off valve so the burner is TURNED OFF before excess pressure builds up in the can
That is why it is a mandatory requirement under AUs standards for them to have a fully functional high gas  pressure BURNER shut OFF vavle
Over sized utensels are then covered
PeterQ.
Good Luck
 I visited a local BigW & picked up a box of these meaning to replace all the old ones.
Had just about finished replacing the cans in the cookers & the spares kept in their cases (I have 2x single & 1 x double burner cookers ), when I had a look at a couple of  spare packages of 'old' cans.  Guess what?  All but 6 of my 'old' cans had the venting device fitted/built in.
So now I have lots of spares.  Which is OK too.  I'll wait to see if my Ubute attracts a recall notice.  I can replace the others over time as conforming ones come on the market at the right price.
Yes I know all about the missing/defective device on the cooker & the (still) risk of fire even with these vented cans.
