Post Info TOPIC: kwikee electric step won't extend
The kwikee electric step won't extend., does anyone have a Motor home with one of these?  normally I open the Van door and it just slides out. Any hint would be appreciated.. and before you tell me, Yes I read the manual, its all Double Dutch to me, ... thanx-Fran
-- Edited by frangipani on Friday 27th of March 2015 01:30:34 PM
"I'll know what I've been searching for,  when I find it"
frangipani53@blogspot.com
Fran I am so glad that you read the manual, if they didn't write it in double Dutch it would make life easier.confuse
I have a switch as I came in the door that I can turn the step on and off. Just a thought. Don't know if you may have accidentally bumped it while climbing ladders a panel beating. biggrinbiggrin
Hope you find the answer as I am sure you will. Xx
-- Edited by shekon on Friday 27th of March 2015 01:43:29 PM
I am fun and adventure. So much to see, so much to do, so many people to meet. Will see, do, and meet all that I can.
biggrinbiggrinbiggrinLOL, thanx Sharon, yes I fiddled with the switch also, it still doesn't work... hope I didn't get any overspray on any sensors?
ps if you need a small panel beating job done just holla..
Would it be a ( Fuse ) by any chance?
Lance C.
Lance C.
 checked the fuse, it looks intack, looked at the meter reading, it said low vaultage, I've plugged her in to the house, the step is working, a bit slow but it works.,
I'll go and get some fuses just incase.,Thanx Lance. -Fran
-- Edited by frangipani on Friday 27th of March 2015 02:57:41 PM
Do you have a multi-meter and do you know how to use it? If you do then chase along the wiring to see where the power disappears. If the power gets to the motor then the motor is buggered or the mechanism is stuck.
 No I dont have one, but I found this in the garage, will this do? It lights up, but can't remember where to put the clamps,
the spring clamp goes to earth and the sharp pointy end to the wire , but it only tells if you have power to the wire not how much
brian
Thanx all, I think its fixed, it had no power., been out to check a couple of times and it works, I sprayed some lubricant on all the moving bits, it sounds good., taken the power off and still working. - Fran
Well done Fran. I'm sure you get a feeling of satisfaction that you achieved it yourself too.
You have now qualified for a certificate in "Fixerupering". Congratulations.
Thanx dougwe, am really trying to get to know as much as I can., have all these tools n things in the garage, its tome I worked out what there for -Fran
