SmartBar
Post Info TOPIC: Fridges (again)
Fridges (again)
Does any one have any idea if its possible to rip a 240 volt compressor out of a fridge and replace it with a 12 volt one? Surely both 240 and 12 volt compressors work on the same principle and the idea should be feasible, hopefully winding up with a half decent R.V. fridge.
Gemmybob.
Tellem-Buggerem
If you dont know what it is, "lick it".
If you still dont know what it is,
Try not to lick it again.
Probably not what you are looking for, but might give you some ideas on building your own fridge..... http://www.ozefridge.com.au/
Also another option for building a conventional style fridge....... http://www.pwt.net.au/refridgeration.htm
And Engel also do a conversion kit as well.... http://www.engelaustralia.com.au/2products_details.asp?pid=12&productid=21607
-- Edited by madaboutled on Monday 16th of March 2015 04:07:51 PM
Well yes you can but the compressor needs to match the fridge size. Using a danfoss compressor the BD35 will probably handle up to about 120Liters, any thing over that size you would be looking at a BD50. The next is the price of compressors a BD35 + its controller is around $600 last time I looked (the compressor & its controller are sold seperatly when new). Ive found its cheeper to buy a second hand Waeco fridge cheep & remove the compressor. This is what I did when I needed a compressor.
D.L.Bishop
Plenty to chew on there, thanks heaps for the links and advice.
Gemmybob
Tellem-Buggerem
