Post Info TOPIC: Installing a diesel heater
We live in Logan City virtually a suburb of Brisbane in Queensland.
Just wondering if anyone living in this region has had a diesel heater installed.
I would like to make contact with you for further discussions.
P.M. me if you wish and I will give you my details. or
the.rodgersplace@gmail.com
Thanks.
Jay&Dee
Did it come with instructions?
Ha!!!ha!!!
I guess it is my fault.
Answer is....  I have not purchased one as yet.  But certainly serious re buying same.
Researched the unit/s on google, but still a little concerned re the working and noise factor, hence my request.
We will in the outback and down south come this winter, so heater is on our must have list.
Anyone in region,  I would appreciate contact.Yhanks
Jay&Dee
Hi Jay & Dee,
We bought our van from a mate who had installed a diesel heater to it.  His advice was to lay all components out on the floor and do all the measuring and thinking before you start to drill holes etc.  Made sense to me.  It is a great thing to have but I have a couple of comments.  There IS a smell outside from the exhaust when you fire it up, and that smell is always there.  I would not use the heater if we were in a caravan park with near neighbors. The people down wind would not be happy.  Of course you would have 240v for a heater in a park anyway.  Fantastic for bush camping though.  I'll be interested to hear from others if they too have a smell from their heater. Maybe it is just an issue with ours.  I understand they were designed originally for European trucks for heat if they were caught in the snow etc.  They are very good, and efficient.  Interested to hear how you go.  Cheers, Bob
-- Edited by Brownie2 on Monday 9th of February 2015 09:31:55 AM
2014 Mazda BT50 towing 2016 Kimberley Kruiser T3.
John I have sent an Email.
Alan
I have purchased a Webasto Thermo Top E that will het the van plus provide hot water, but have yet to install it.
Heating the HWS with diesel instead of gas was a prime objective to save cost and reduce reliance on gas.
There is plenty of discussion on this and every other caravan/camping forum. Just click on "Search" near the top of this page and type in "diesel heat" (that will capture heating as well as heater.)
 That is not my experience. I have a Webasto, there is a whiff of diesel smell on the first start up but not on subsequent running. I do run mine in parks when I require a quick heat up after coming home from visiting at night. I run it a while in conjunction with the electric fan heater until the climate stabilises to my liking. I frequently talk to my neighbours the following morning. Even those in tents have not been aware that I have run the diesel heater the previous evening.
Hi there
I have installed a planar diesel heater in our motor home not hard to do bought it off pinnacle wholesales on eBay $800 with separate diesel tank they are good to deal with.
It works very well slightly noisy but not annoying very good on fue
Dragonfly 1
C Geyer
 Same here as with Peters responce.
Ours is the Eberspacher (Dometic)    They need to be serviced  yearly.   Renewing the "Glow Plug Screen" and the Fuel Pump Filter Screen".       Also cleaning the "Glow Plug"  with emery or scotch bright.    Not forgetting  clean out the little  port where the Glow plug is housed.
Mine started smoking on start up,  last September, but ran OK when heated up.     Done the maintenance and all is OK again and running  well.
If  camping in a C.P.  on 240v  we just run the little electric heater.   Our van is so small that it takes no time to heat it up.
P.S.  This had not been serviced in two and a half years.
PPS
-- Edited by elliemike on Monday 9th of February 2015 07:43:15 PM
-- Edited by elliemike on Tuesday 10th of February 2015 12:08:07 AM
-- Edited by elliemike on Tuesday 10th of February 2015 04:57:24 PM
Mike & Ellie
dragonfly1 wrote:
Hi there
Dragonfly 1
I've been thinking of purchasing one of these and then just read about another brand which requires yearly servicing of the glow plugs etc.  Do you have the same with the Planar brand?  I also read on the Jayco forum that people with these heaters found they reduced the outside noise if the put a bend in the exhaust pipe!
Glen
Glen
Depending on the kit you buy there may (should) be a muffler for the exhaust pipe and another for the intake.
I got mine from a Tasmanian business http://www.dieselheat.com.au so I had an aussie speaking expert to talk to if needed.
I was very happy with the product and support from there.
Actual fitting was pretty straightforward, just read, read & re-read instructions to be very clear what will go where especially prior to cutting the 145mm hole in the floor! crybiggrin
I am so looking forward to winter now to try it out in anger.
Neil & Lynne
Pinjarra
Western Australia
Hi Glen
i fitted a muffler to the exhaust and there is nothing in the instructions about any yearly maintence and I have not done any.
If you get the diesel heaters up on pinnacle wholesales web site you can bring up a copy of the instruction manual hope this helps you
Dragonfly1
C Geyer
