Post Info TOPIC: porta loo
porta loo
Just a couple of questions on the subject
the cheap chem that goes in top flush tank of a porta loo
and the special paper your supposed to use in them ,does it work or just a sales gimmick
thanks
The Master
All you need is Woolworths Homebrand Napisan , a capful every nowand again in the toilet.
Toilet paper , all you need is basic 2ply. Anything thicker may not break down.
Happy Wanderer
Don't worry, Be Happy!
How, David, are you and Lesley planning a big s..t in mate confusesmile
Sorry all smile
I have sent a PM mate.
The pink chemical that goes in the top often causes black 'stuff' to grow in the top tank, stick to plain water.    As said above Nappy or laundry soaker from the supermarket in the bottom tank is I feel the best choice, cheap, no nasty chemical smell and easy to buy and carry.   Normal toilet paper is fine, just try not to use too much of it.
We put Home brand Napisan in the bottom tank and just plain water in top tank , Mix up some pine a clean in spray bottle to spray the bowl when ever
thanks for replies
Have never used any special paper just use the same quality paper that we use at home and it has never failed to break down before emptying and have only ever used generic napisan just make sure it is 34% strength sodium percarbonate with no other additives.
David
Those using the Woolies brand should be aware that, in their wisdom, Woolies have reduced the sodium percarbonate to 24% or 28% now ! read this in another forum.
We have reverted back to the original Nappisan Vanish in the pink container, as it seems to have a nicer odour , not perfumy just a fresh smell. It's often on special at one of the big 2 .
-- Edited by banjo on Monday 9th of February 2015 10:38:18 AM
brian
I have previously tried using Nappisan but have had white scale build up in canister I have also tried dissolving the Nappisan but still got scale build up can anyone tell me if I am doing this incorrectly.
Hi David, have had the big s..t in yet mate confusebiggrin
No not to date but if that solves the problem we may need to try it
The Happy Helper
 Well,well - just went and had a look, and yes ,down to 24%!!!!!!!!  We thought we were getting slack, and not using it often enough, but this answers that!  Will have to look for another one, and use it daily in the meantime.
might even write to them and ask why it has chagrd.
another thing - if you are only using it for urine, you would better off just using some Eau alyptus oil, capful a day or so, the sodium percent. Is to break up no. Two's and toilet paper.  Does not much at all for no. One's!!
jules
(Ben, aged 10)
 Just put some citric acid or vinegar overnight to soak and the scale will be gone, it is just limescale usually from the high mineral content water in some areas.
brian
Thanks Brian I have some CLR in the shed will try it tomorrow, I knew I could rely on the forum for an answer Thanks again Brian biggrinbiggrinbiggrinbiggrin
I agree with you Meredith....but ONLY if it is left in there I have found. I learnt the hard way (don't we all!!) after a trip and found the black stuff a few weeks later. I got it all out eventually....and now the loo gets a good flush out and rinse at the end of every trip...and no more black stuff.
Have been using the pink chemical as per directions since ...and all good. Just clean out loo properly at end of trip before storage and all is sweet.
HTH.
Cheers  Keith
