Post Info TOPIC: Grey Water Hose to 90mm Valve... ?
Hi Travellers. I have recently bought an Isuzu Elf with a grey water discharge valve with a 90mm OD valve body that I believe needs a hose connected to it so I can drop my gray water into bit. (Yes?). So... I have been looking for 90mm hose collapsible hose but can't find any. Am I barking up the wrong tree? The bus has a stowage for such hose with a 100mm ID tube by 800 mm long to accept such a hose. Please advise... Thanks. Jim smile
Jim Moon (SOF)
smile  Hi Jim, yep, it's the wrong tree, wink  You will not get collapsible hose in that in that Dia, I assume that thae 90mm is the'OD' and you will find that the hose you require will be 75mm NB - [ 3'' ] go to a Irrigation Supply place, They will have A hose called ''Layflat''  that should do the job for you, seeing as how you only need to Gravity drop the water, ?  You cannot get collapsible hose in that size, only Ducting, but it is NOT made for water service, Any Hose supply Co near you should be able to assist, !  Hope this helps you a little,  Dazren
IF IT IS TO BE !! IT IS UP TO ME !!!
Thanks Daz, by the way how close can one get one's rig to the pit. I haven't had such luxuries before. As luck would have it, I've just got back from Clark Rubber fom buying a mattress and I found some 65ID black curly hose, so I bought 800mm of it. Hoping now to get a fitting from Bunnings and that I can get my bus close enuf to the pit. Cheers... J
Jim Moon (SOF)
