Post Info TOPIC: Leaking Window Seal
Leaking Window Seal
Thw window above the sink is letting rain in, question, do I have to remove the existing seal around the window, or can I put the Sica Flex straight over it?
Now be kind, this is the first time doing this, -Fran
"I'll know what I've been searching for,  when I find it"
frangipani53@blogspot.com
You could clean it and put silicon over the seal.... But if it's a opening window it would be better to source exactly where the leak is coming in and repair it or re seal it.
Thnx Totalrv, its a sliding window, up and down, is that what you mean?
Try closing the window and get someone to spray it with the garden hose while your inside and see exactly where the water is coming in,then you can work out if it's a rubber seal issue or just the window frame needing sealing/silicon :)
hi fran,, how you going,, ME HAD THE SAME PROBLEM,, and I fixed it buy closing the window,, between you and I,, Me has a lot of problems,, CHEERS Lockie ,, ( travel safe )
 Thankyou Totalrv, sorry I didn't get back to you, its been raining, cant get to hose it. Should be ok later this arvo and then I'll do it
 Hi Lockie,  you still chasing your shadow???? miss you guys, been industrious, I put a screw up that holds the curtain rail up, I found a screw with a metal clip on the end and it worked, I think it was off a car., LOL, Yes I now Me has a lot of problems, one is he doesn't know his solar from his generator. LOL
 ok, sprayed the window, no water coming in, seems it only happens if its heavy rain, or raining for a few days? Has anyone experienced this? Could the water be coming in from somewhere else? - Fran
STARTED A NEW THREAD WATERVIS COMING FROM THE RANGEHOOD CAP ON THE ROOF
-- Edited by frangipani on Sunday 11th of January 2015 04:28:39 PM
Sliding windows, these overflow inwards when the drain holes block up. Check underneath outside, there should be several longitudinal slot holes visible, make sure they are not blocked up.
Thanx PeterD, I found out that its actually coming in from the vent ontop of the rangehood. Had a look how its all put together, will try and dismantle it tomorrow.
http://pages.ebay.com/link/?nav=item.view&alt=web&id=321636461428
 ok, pulled it all apart cleaned it, couldn't see any O ring, so now will get the levelling stuff.,
Thanx for your help
