Post Info TOPIC: INSTANTANEOUS HOT WATER SYSTEM......
.....in a caravan. Has anyone got one and are you happy with it?
I have one fitted to the new "Chief" but the water is only Luke warm and would be far from suitable in colder weather.
Has anyone had this problem and overcome it and how please.
Goodmorning Dougwe
From reading the blurbs about these devices, I understood that they had a temp control thermostat. Please correct me if I am wrong.
If your case is the norm I will stop being interested in them.
(Phil C) Retired
12 years RAAF
 Chief, there's more then one brand out there. Which one have you got?
Larry
Hi Doug
Is your sink tap hot but your hand basin & shower only warm?
If that's the case it may be as easy as altering +/- on the cold water mix % going into the tempering valve.
The tempering valve is there to prevent being burnt in the shower.
If the sink water temperature is only warm there must be a thermostat there somewhere to adjust it.
Hope this is of some use.
Cheers, John
I know of a person who had this problem. The remedy was that their pump did not have sufficient flow rate. Fine for an accumulation heater but not an instantaneous.
If we are going to be altruistic I want to get something out of it
Some tech info as requested,
Girard Demand Tankless Water Heater, Model GSWH-1M. LPG only.
There is a " 12v Gas Modulation Control " in a overhead cupboard inside the van. It is set to highest setting as we speak. I have tried all settings. The destruction manual says to purge all taps before first use which has been done. All taps are the same John (HC).
There is another van here with the same service and same problems.
I have no personal knowledge of your heater Doug ... but I found the Owner's Manual on my best friends site (Mr Google biggrin)
Although, I would assume you already have a copy of it in the van.
http://greenrvproducts.com/wp-content/uploads/2014/05/GSWH-1M-OM-EngFr-Rev-3.pdf
Go to Page 11, perhaps this would be helpful?
Otherwise, I have nothing of further substance to offer cry
cheers - John
Not related Doug, but mine has a tempering valve for the shower at the back under the van
ken
DUN WURKUN
Rocky, I have tried various positions on the GMC with no success.
Ken, no valve as you describe that I can find. Someone here just had a look at the unit from outside but no adjustments to be found and none inside.
My one is a Rio Grand and has a digital temp guage which is only on when the heater is being used, eg when the taps are running. I sugest you run the taps and go and see if there is a guage on the unit.Mine gets water too hot to use. Will post pics if you want.Bill
Doug maybe the water runs to fast true the system
It needs time to heat up maybe you can turn the pressure down
( That is if it is the same or similar as JC's old system )
you can always give Chief a call
Cheers John
-- Edited by Cruising Cruze on Monday 22nd of December 2014 03:58:09 PM
I second that one. try slowing the water flow and see if it gets better
Thanks all, I have tried to adjust the mixer taps and seem to get warm water, much better than before.
