SmartBar Floriade Darwin International Film Festival Goodlife RV Resorts Celtic Fest
Post Info TOPIC: Problems With Ice
Problems With Ice
How many of you GN's use ice to keep things cool only to have a watery mess at the bottom of the cooler/esky? If you have a food vacuum sealer your problem is solved. Split your bag of ice into manageable sizes and vacuum seal the ice. The ice still keeps everything cool and on the plus side, when it has melted snip the corner of the bag and add it to your drinking water.
A note of caution: make sure that the ice is specified as drinking water quality.
We did this last trip and it worked well. No mess.
This would be better in "Hints Tips and Great Ideas" Umpie 1. Sounds good though.
Phew! I thought the thread title referred to the drug "Ice" Umpie! thank heaven that was wrong!
Cheers,  Gerty. ... at home
Been watching Breaking Bad a bit too much and looking for a way to supplement your income a little smilenono
See you on the road
I must have had a sheltered upbringing, when I saw "Ice" all I thought of was frozen water cry
For ice bags I use the blue gel bags from bunnings, a couple bucks each & stay frozen much longer than ice. Don't be tempted to drink it when thawed though ha ha
Neil & Lynne
Pinjarra
Western Australia
MY23.5 Ford Wildtrak V6 Dual Cab / 21' Silverline 21-65.3
' 1260w Solar: 400ah Lithium Battery: 2000w Projecta IP2000 Inverter
I, sometimes, use my largish, blue icebox (EvaKool, I think) and can fit a small square mop bucket inside. The bag of ice goes into that and retains the water and keeps everything else reasonably dry. The bonus is that it leaves iced drinking water without contamination.
This is NOT sarcasm.
The Phantom
What I have seen is people using wine cask bladders for ice bags, freeze them after filling with water as the OP said, when thawed there is a tap to use the water for drinking.
Neil & Lynne
Pinjarra
Western Australia
