Post Info TOPIC: Electric 12vDC screw jack and Masters generators.
Can any one tell me where to get a 12v screw jack to replace my jockey wheel?
Not to actually replace it but to take its place during initial setup.
I am continually having to remove my jockey wheel and reposition it to get enough height. The other day at work I saw an electronic screwjack fitted to a van and it had about 18 in of lift and fall on it. This would suit my application superbly.
Has anyone tried the TPE brand of generators from Masters?
My friend has just purchased one it is rated at 2000w peak 1700 normal output. It was $850 and seems like a nice little unit with local warranty.
M&D
Never stop learning.
Hi M&D, have a look at the link below. Do not know anything about it, just found the add.
http://www.ebay.com.au/itm/Power-Jack-Atwood-OEM-Proven-New-1500lb-Car-Caravan-Trailer-Boat-Accessories-RV-/171465482354?pt=AU_Car_Parts_Accessories&hash=item27ec23a072
Discovery 4,
Retreat Brampton
Try a 4WD shop , maybe a good place to start.
Dennis and Yvonne .
Retired sparky of 50 years.
JUST COASTIN`
M & D, have you looked at the Trail-A-Mate hydraulic jack. You can also use it to lift the van to change a flat tyre.
Larry
Hi M&D
          i have had mine about 2  years reason for it was I have Arthritis in my hands and this helps heaps,I bought mine from REPCO for under $200.00    $184.00 I think ,it lifts my van no problem the van is  21.5  FT JAYCO  WESTPORT  with a ball weight of 250KG,  hope this helps.
