Post Info TOPIC: Raising van ground clearance
Need a little more ground clearance for the Avan Erin MK2. About 50 to 70mm. It is std single axle slipper leaf springs with shokies. The van is quite low,causing probs with drive ways and sloppy site, difficulty fitting jockey wheel at times. Any reasonble suggestions welcome.
Ta Lefty
Leftwing
Getting into the good life now!
Our travelling companions also had a clearance problem with their Avan, a different model though. They rotated the axle 180 degrees. Made a heck of a difference.
cheers Stuart and Dianne
Quo vadis
I just got mine under slung. She's looking peachy ;) the water tanks sat fairly low, better clearance now wink
MaryJane
Did you get it done and if so what sort of cost please
Allan
Mitsubushi Triton Diesel Twin Cab
Concept Ascot ll  20.6ft
Hi, Allan!
I recently had my Avan Rhys hardtop underslung which raised it about 100mm. The result was amazing - no complaints at all except I had to buy a new 3 step ladder ($38 at Costco) to replace the old 2 step one and we now have to use a step at the door. Cost $450 at B & B caravan Services, Brendale (northern Brisbane suburb). They were recommended to me and I now recommend them to every van owner I know.
Best regards,
Chris
Licensed Electrician, Electronics, Gaming & Computer Technician. Now retired and loving it!
