Post Info TOPIC: Fridge shade
Fridge shade
Just bought sunshades for the awning so thought I would include a fridge shade at the same time.
Could anyone that uses a fridge shade please advise where to fix the sail track, above or below the upper fridge vent?
I'm thinking above the upper vent will shade the whole side but might restrict heat escaping from the vent.
Nigel
I have only ever seen above the top vent Nigel. If it was me fitting it I would go up near the top edge of the roof.
I fitted a sail track right along the whole length of the van.  Fixed it to the top of the cover strip over the wall/roof joint.  (Had a professional do it actually - pop rivets & sikaflex)
I purchased a shade cloth screen that fits either there on the fridge side, or along the awning roller as a privacy/wind screen.  May get a second one if it proves satisfactory.
Haven't tried it yet.  Not been hot enough.
-- Edited by Cupie on Friday 26th of September 2014 05:30:54 PM
-- Edited by Cupie on Friday 26th of September 2014 05:32:31 PM
This is what I did, works a treat on hot days.
Live long and Prosper
See photo attached for our screens.  Unfortunately I don't have photos of all three screen up at the same time. The long wall can also be used on the annex side.  We also have a small piece of shade cloth 2.4x3 metres which we use wherever it is needed.
  • We  have a long wall which doubles as a carport or just protection from the western sun.
  • A  Fridge vent screen - peg it out on an angle so as to allow the vent to breath.
  • A screen to protect our generator from bad weather when in use
These are all able to be attached by a sail track.
I fitted our track above the top outlet.  Figured the more shade you can get on the side of the 'van the better for the fridge and if you are using shadecloth type material - the hot air will vent through it.
Only fools are certain.  It takes a wise man to be confused.
We fitted ours above the top vent, but it would be better if it covered the whole length of the van, a one-meter wide one doesn't help much.
Cheers,  Gerty. ... at home
If you install the track immediately above the top vent you will obstruct the air flow somewhat. The heat from the gas flue could also singe the material. If you install the track fairly high above the top vent you should have plenty of air escape area to the sides of the awning.
How,
Thanks for that Phil, I reckon that's what I will do.
I also like the way you colour match the shade and BBQ. Well done smile
Dougwe wrote:
How,
 Thanks Dougwe, perhaps the twins and you will join me in a bevy under the blue one day.......
I hope you are well mate.
Thanks everyone for your replies.
Look like fitting above the top vent is the preferred method.
I like the idea of the full length shade as well so will fit sail track alone the top edge.
Thanks again
Nigel
